Ethernet Products
4637 Discussions
Hi WCAO2, my name is Carlos test engineer from Honeywell Aerospace, I need the IBIS file model of WG82574 GbE controller chip. The file doc. ID 377975 is available and how I can get this file. Thanks for your help.
CGonz11
Daniel_D_Intel1
Hello CGonz11, Thank you for posting in Intel Ethernet Communities. Please note that the IBIS model requires Resource and Design Center access and is under a non-disclosure agreement. Please register at Resource and Design Center. You will be able to get the IBIS model from the RDC Library. If you have questions regarding the IBIS model, please check with the Embedded Community. Find the Resource and Design Center below: https://www.intel.com/content/www/us/en/design/resource-design-center.html Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
