Ethernet Products
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4743 Discussions
How can i enable SR-IOV for the "Intel Corporation Ethernet Controller 10G X550T (rev 01)" in CentOS?
YATINDRA_S_Intel
I have NICs of type "Intel Corporation Ethernet Connection X722 for 10GBASE-T (rev 03)" and "Intel Corporation Ethernet Controller 10G X550T (rev 01)" in a server Intel Purely S Motherboard S2600WFD . Although SR-IOV is enabled in BIOS I have sriov VFs entries for the first type, but not for the second.
The card detail from o/p of command lshw -class network is like:
 description: Ethernet interface
    product: Ethernet Controller 10G X550T
    vendor: Intel Corporation
    physical id: 0
    bus info: pci@0000:86:00.0
    logical name: enp134s0f0
    version: 01
    serial: xxxxxxxxx
    capacity: 10Gbit/s
    width: 64 bits
    clock: 33MHz
    capabilities: bus_master cap_list rom ethernet physical tp 100bt-fd 1000bt-fd 10000bt-fd autonegotiation
    configuration: autonegotiation=on broadcast=yes driver=ixgbe driverversion=5.5.5 duplex=full firmware=0x80000483, 17.5.9 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
    resources: irq:298 memory:d3c00000-d3ffffff memory:d4004000-d4007fff memory:d4200000-d427ffff
 *-network:1 DISABLED
and o/p of ethtool -i
controller-0:~$ ethtool -i enp134s0f0
driver: ixgbe
version: 5.5.5
firmware-version: 0x80000483, 17.5.9
expansion-rom-version:
bus-info: 0000:86:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Can you tell me what could be reason, and what should I do? or it has supplier specific things?
Caguicla_Intel
Hello YSHAS,
Can you share if the Intel Corporation Ethernet Controller 10G X550T (rev 01) is embedded on the server board S2600WF or is it a PCIe Ethernet card?
Please also confirm if you have already tried the suggestions from the forum link below that you have mentioned?
https://forums.intel.com/s/question/0D50P00004EtnOUSAZ/how-can-i-enable-sriov-for-the-intelr-ethernet-10g-2p-x550t-adapter-in-linux
We look forward to your response.
In case we don't hear from you, we will follow up after 3 business days.
Crisselle C
Intel® Customer Support
YATINDRA_S_Intel
It isPCIe Ethernet card.
I have tried solution mentioned on the link and have commented on that Link as well. Surprising for me is that, on Board ethernet card works for SR-IOV but not this PCIe NIC card.
Caguicla_Intel
Hello YSHAS,
Thank you for the reply.
Can you share the PBA and serial number of the Ethernet adapter? You may refer to the link below on where to find the PBA number. Providing the photos of the adapter focusing on the markings (white sticker) found on the physical card will do as well for us to double check on it. The PBA is consist of 6-digit number located at the last part of the serial number, it could help us identify if it is Retail or OEM version on Intel Ethernet adapter.
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-i-o/ethernet-products.html
We hope to hear from you soon.
Crisselle C
Caguicla_Intel
Hello YSHAS,
Good day!
Please provide the requested additional information for us to continue to check on your request.
Awaiting to your response.
We will follow up after 3 business days in case we don't receive a reply.
Crisselle C
Caguicla_Intel
Hello YSHAS,
How are you today?
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future.
Crisselle C
