Ethernet Products
4865 Discussions
How do I enable rx-fcs and rx-all for Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Card?
WLock
Currently, I have the following:
# ethtool -k p1p2
Features for p1p2:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: on [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp6-segmentation: on
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: on
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: on [fixed]
tx-gre-segmentation: off [fixed]
tx-udp_tnl-segmentation: on
fcoe-mtu: off [fixed]
tx-nocache-copy: on
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
I need rx-fcs and rx-all on. The only message I could find on the topic was from 2014, and said that this might be supported in a future release.
We're using:
driver: ixgbe
version: 5.0.4
firmware-version: 0x18b30001
bus-info: 0000:04:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Linux HOSTNAME 3.10.105-1.el6.elrepo.x86_64 # 1 SMP Fri Feb 10 10:48:08 EST 2017 x86_64 x86_64 x86_64 GNU/Linux
LSB Version: :base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch
Distributor ID: CentOS
Description: CentOS release 6.8 (Final)
Release: 6.8
Codename: Final
Not sure what other data to provide.
If this card/chipset will not support this, what will?
WLock
Also the output of dmesg:
# dmesg | grep ixgbe
ixgbe: 0000:04:00.0: ixgbe_check_options: FCoE Offload feature enabled
ixgbe: allow_unsupported_sfp Enabled
ixgbe 0000:04:00.0: irq 77 for MSI/MSI-X
ixgbe 0000:04:00.0: irq 78 for MSI/MSI-X
ixgbe 0000:04:00.0: irq 79 for MSI/MSI-X
ixgbe 0000:04:00.0: irq 80 for MSI/MSI-X
ixgbe 0000:04:00.0: irq 81 for MSI/MSI-X
ixgbe 0000:04:00.0: irq 82 for MSI/MSI-X
ixgbe 0000:04:00.0: irq 83 for MSI/MSI-X
ixgbe 0000:04:00.0: irq 84 for MSI/MSI-X
ixgbe 0000:04:00.0: irq 85 for MSI/MSI-X
ixgbe 0000:04:00.0: PCI Express bandwidth of 32GT/s available
ixgbe 0000:04:00.0: (Speed:5.0GT/s, Width: x8, Encoding Loss:20%)
ixgbe 0000:04:00.0 eth0: MAC: 2, PHY: 1, PBA No: E66560-003
ixgbe 0000:04:00.0: 00:1b:21:xx:xx:xx
ixgbe 0000:04:00.0 eth0: Enabled Features: RxQ: 8 TxQ: 8 FdirHash
ixgbe 0000:04:00.0 eth0: Intel(R) 10 Gigabit Network Connection
ixgbe: 0000:04:00.1: ixgbe_check_options: FCoE Offload feature enabled
ixgbe 0000:04:00.1: irq 86 for MSI/MSI-X
ixgbe 0000:04:00.1: irq 87 for MSI/MSI-X
ixgbe 0000:04:00.1: irq 88 for MSI/MSI-X
ixgbe 0000:04:00.1: irq 89 for MSI/MSI-X
ixgbe 0000:04:00.1: irq 90 for MSI/MSI-X
ixgbe 0000:04:00.1: irq 91 for MSI/MSI-X
ixgbe 0000:04:00.1: irq 92 for MSI/MSI-X
ixgbe 0000:04:00.1: irq 93 for MSI/MSI-X
ixgbe 0000:04:00.1: irq 94 for MSI/MSI-X
ixgbe 0000:04:00.1: PCI Express bandwidth of 32GT/s available
ixgbe 0000:04:00.1: (Speed:5.0GT/s, Width: x8, Encoding Loss:20%)
ixgbe 0000:04:00.1 eth1: MAC: 2, PHY: 19, SFP+: 6, PBA No: E66560-003
ixgbe 0000:04:00.1: 00:1b:21:xx:xx:xx
ixgbe 0000:04:00.1 eth1: Enabled Features: RxQ: 8 TxQ: 8 FdirHash
ixgbe 0000:04:00.1 eth1: Intel(R) 10 Gigabit Network Connection
ixgbe 0000:04:00.1: registered PHC device on p1p2
ixgbe 0000:04:00.1 p1p2: detected SFP+: 6
ixgbe 0000:04:00.1 p1p2: NIC Link is Up 10 Gbps, Flow Control: RX/TX
Note also that the results are the same if allow_unsupported_sfp is on or off. Currently there is a supported sfp in place. I've tried it both ways.
Hi Vladinatrix,
Thank you for the information. Let me check on this.
Rgds,
wb
Hi Vladinatrix,
Can you share also where is the information you mentioned that the topic you can find was from 2014?
Rgds,
wb
HI Vladinatrix,
Please feel free to update me.
thanks,
wb
