Ethernet Products
4873 Discussions
How do you enable promiscuous mode on l219-LM updating drive does not seem to help
CSzcz1
l219-LM using wireshark or NI observer same results nic is not in promiscuous mode OS Windows 10
Hi Caseys,
Thank you for the post. This is something to do with the nnetwork management agent or other software (such as "Network sniffer") , you may refer to this website for reference.
http://www.intel.ph/content/www/ph/en/support/network-and-i-o/ethernet-products/000007255.html
Rgds,
wb
CSzcz1
The l219-LM nic does not work in promiscuous mode with a windows 10 and 7 machine the l218-LM works with no problems with the sniffer software
Hi Casey,
Thank you for the update. Have you had any chance of checking with the software vendor?
I will check if there is any information.
wb
CSzcz1
I contacted the software vendors they informed me it is a problem with the Intel nic driver
Hi Caseys,
Thank you for the update. Can you share which software vendor confirmed it is the NIC issue and is there any reference ticket number from their end?
For the meantime, can you also provide the SSU log, download the SSU tool from
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility and run the tool.
What is the brand and model of your system? (e.g board model and exact NIC driver version) and more information about your system.
wb
Hi Caseys,
Good day. Can you help provided the requested information?
wb
