Ethernet Products
5374 Discussions
How to add mac address ini210 iNVM hex file
Dileep
 I have created a custom carrier board using i210 and Jetson TX2. I have successfully programmed iNVM of i210using eeprom and generic hex file given by the tool for testing. But when the driver is booting an error is showing
igb 0000:01:00.0: Invalid MAC Address
igb: probe of 0000:01:00.0 failed with error -5
I have checked the NVM it is programmed correctly. Do I have to separately give MAC address to i210 or can I edit the hex file and flash it again? The same Jetson I have connected to a development board with preprogrammed i210, there MAC address is detecting properly.
