Ethernet Products
5776 Discussions
How to disable vlan strip ?
rshal2
New Contributor II
I am using intel igb driver with linux.
The driver strip the packet from vlan and this is not what we need.
We must have the vlan information.
How can we disable this vlan stripping ?
I've seen that there are many who had the same issue, but did not see any solution for that.
Please advise.
Ran
Hi Ran,
Thank you for contacting Intel.
You can configure the adapter to allow VLAN tag to pass thru Windows* Registry Settings. Please refer to website below for details:
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005498.html http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005498.html
Hope this is helpful.
Sincerely,
Sandy
Hi Ran,
Sincerely,
Sandy
rshal2
New Contributor II
Hi Sandy,
Thank you for the reply.
As I wrote in the post above, we are using Linux - not windows.
So we need a solution for the igb driver in Linux.
I assume it will be in sort of ethtool feature enable/disable or driver rebuild using other flags.
We delved into the driver and found no solution yet.
We also found this question already been raised by others in several mailing forums, but no answer been given yet.
Ran
