How to identify the full name/description of my Intel(R) Ethernet 25G 2P E810-XXV Adapter.
Is it
- Intel Ethernet Network Adapter E810-XXVDA2: which supports dual 25GbE ports.
or
- Intel Ethernet Network Adapter E810-XXVAM2: which supports dual 25GbE ports with advanced offloads.
DataBusWidth
8x or x8
Description
DeviceDescription
NIC in Slot 1 Port 2 Partition 1
DeviceNumber
0
DeviceType
PCIDevice
FQDD
NIC.Slot.1-2-1
FunctionNumber
1
InstanceID
NIC.Slot.1-2-1
Manufacturer
Intel Corporation
PCIDeviceID
159B
PCISubDeviceID
0002
PCISubVendorID
8086
PCIVendorID
8086
SlotLength
Long Length
SlotType
PCI Express Gen 4
And if check via cli:
Ethernet controller [0200]: Intel Corporation Ethernet Controller E810-XXV for SFP [8086:159b] (rev 02)
Subsystem: Intel Corporation Ethernet 25G 2P E810-XXV Adapter [8086:0002]
Is there a way or any command to check the exact name?
any answers?
Correct me if I'm wrong, according to the documentation links you shared me -> that implies:
E810-XXVAM2 is an Ethernet Controller
and
E810-XXVDA2 is an Ethernet Network Adapter or NIC
And as per the specifications I have: my NIC should be E810-XXVDA2, which is using Controller: E810-XXVAM2.
Right?
