Ethernet Products
5744 Discussions
How to know the changeset of two different driver versions?
MMani7
For a study, I would like to know the differences between two Intel Network driver versions (example: delta changes/fixes/improvements from v18.6 and v21.1)
In the Intel websites, I don't get this information. can you please update from where can I get these information?
Appreciate your help!
Hi Prabu,
Can you check if these information are what you need?
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005840.html
wb
MMani7
Many thanks for the link. This link has the overview of the change set but I would like to know the known issues/bugs in the previous release and fixes/improvements/new features in the next release.
MMani7
Is there any link for the chipset versions?
Hi Prabu,
Can you share what is the exact ethenet controller or network adapter you refer here?
thanks,
wb
MMani7
sorry for the late reply.
The Network adapter is "Intel(R) 82576 Gigabit Dual Port Network Connection" and "Intel(R) Gigabit CT Desktop Adapter".
Hi Prabu,
Thank you for sharing the information. Will need to check if the information is available. I will update you if there is any finding.
rgds,
wb
Hi Prabu,
Good day. Can you check if below information meets your requirement:
1) Version 21.1 https://downloadmirror.intel.com/18713/eng/readme.txt
2) Version 18.6 https://downloadmirror.intel.com/23238/eng/readme.txt
wb
MMani7
Thanks for the update. This is ReadME.txt file which comes with all the driver version I believe.
This information is not the one which I am expecting. My expectation is to have the improvements and fixes from the previous release and the current release.
Hi Prabu,
Thanks for the reply. I will have to check.
rgds,
wb
Hi Prabu,
Good day. Can you share also what is the OS and driver version loaded for those 2 NICs?
I understand you are looking for 18.6 and 21.1, but 18.6 and 21.1 refers to the software package version, to be more specific, please tell me the exact driver version installed.
wb
MMani7
The OS version is Windows Embedded Standard 7 SP1 x64.
The software package version that I look for is v19.1 and v21.1.
The exact driver version for 19.1 is 12.7.27.0.
Currently I don't have the exact version for 21.1.I will share if I come to know this exact version.
Hi Prabu,
Thank you. I will wait for your further update.
rgds,
wb
MMani7
The exact version of v21.1 is 12.7.28.0
AlHill
This thread and this one should be merged.
Doc
Hi Prabu,
Please let me know if the information provided on other thread meets your requirement.
https://communities.intel.com/thread/111204 https://communities.intel.com/thread/111204
wb
MMani7
I raised the other thread to know the same version history for Chipset drivers.
Hi Prabu,
I would like to know if further assistance needed ?
thanks,
wb
