Ethernet Products
5045 Discussions
How to perform raw Ethernet with Intel Pro 1000 on Windows
JGarn6
I need to transmit/receive raw Ethernet packet for fast communication in Windows 7+. Is there a way to do that directly with Intel NIC driver or API ?
st4
New Contributor III
Hi Jygarneau,
Thank you for the post. Can you help clarify what is to transmit/receiv raw ethernet packet for fast communication? This might be done by using software. Please provide more information for me to check. thank you.
rgds,
wb
JGarn6
I need to send Ethernet packet at high speed. We can't do this with Winsock. I can use Winpcap but it's not very fast. So, I'm searching a simple method to acheive this and want to check if Intel driver can do that directly from a C or C++ application to send and receive. I'm implementing a EtherCAT master. Thank you.
st4
New Contributor III
Hi Jygarneau,
I need to check on this. What is the exact PRO 1000 network adapter model you are referring here? Thanks.
rgds,
wb
JGarn6
Hi rgds,
The card model is not the most important. I want to know if I can call an Intel driver directly in C to send and receive Ethernet packets without using winsock. I want a simple interface to send Ethernet frame, this is the primary purpose of a network card. When I buy a PCIe card, the company have Windows driver and DLL to get service from the card. I want to know if Intel have these and where it is documented. Thank you!
st4
New Contributor III
Hi jygarreau,
Thank you for the information. I will check on this.
rgds,
wb
st4
New Contributor III
Hi Jygarneau,
Good day. Further checking I am sorry to inform you the Windows driver source code is not available.
Thank you for your time on this matter.
rgds,
wb
