Ethernet Products
4359 Discussions
Hyper V install order
I have read that with Broadcom and or HP servers that the install order with Hyper V and NIC teaming is CRITICAL.
Is this so with Intel NIC's/teaming software?
The order I have read about goes something like this...
  1. Install Windows 2008 R2
  2. Install the Hyper V role
  3. Install NIC teaming drivers/software
  4. Configure team/s
  5. Configure Hyper V networking to point to a team.
Again I have read this as it pertains specifically to HP Proliant Servers and HP NIC teaming sofware and I have seen it (from along time ago 2008/2009) about Broadcom NIC's
I have done it this way so far...
  2. Install NIC teaming drivers/software
  3. Configure the teams
  4. Install the Hyper V role
  5. Configure Hyper V to use a team
It works fine in testing but......if I am going to see network issues they will probably show up when I put a much bigger load on them. I really dont want to rebuild my servers...but if I have to I will.
Is there any guidence from Intel on the correct or supported order of things?
Thanks!
Patrick_K_Intel1
Thanx for visiting our forum.
The Intel Ethernet teaming software solution is quite robust and has no such restrictions. It makes no difference in which order you install.
Happy virtualizing!
