Ethernet Products
5736 Diskussionen
I am facing issue XL710 QDA2 link not detected.
apapr
Einsteiger
8.235Aufrufe
I am facing below issue, below if output of modinfo i40e
filename: /lib/modules/4.4.0-31-generic/updates/drivers/net/ethernet/intel/i40e/i40e.ko
version: 2.7.29
license: GPL
description: Intel(R) 40-10 Gigabit Ethernet Connection Network Driver
author: Intel Corporation, <e1000-devel@lists.sourceforge.net>
srcversion: 2212C8D31172FBDBC9A1647
alias: pci:v00008086d0000158Bsv*sd*bc*sc*i*
alias: pci:v00008086d0000158Asv*sd*bc*sc*i*
alias: pci:v00008086d000037D3sv*sd*bc*sc*i*
alias: pci:v00008086d000037D2sv*sd*bc*sc*i*
alias: pci:v00008086d000037D1sv*sd*bc*sc*i*
alias: pci:v00008086d000037D0sv*sd*bc*sc*i*
alias: pci:v00008086d000037CFsv*sd*bc*sc*i*
alias: pci:v00008086d000037CEsv*sd*bc*sc*i*
alias: pci:v00008086d00001588sv*sd*bc*sc*i*
alias: pci:v00008086d00001587sv*sd*bc*sc*i*
alias: pci:v00008086d000015FFsv*sd*bc*sc*i*
alias: pci:v00008086d00001589sv*sd*bc*sc*i*
alias: pci:v00008086d00001586sv*sd*bc*sc*i*
alias: pci:v00008086d00001585sv*sd*bc*sc*i*
alias: pci:v00008086d00001584sv*sd*bc*sc*i*
alias: pci:v00008086d00001583sv*sd*bc*sc*i*
alias: pci:v00008086d00001581sv*sd*bc*sc*i*
alias: pci:v00008086d00001580sv*sd*bc*sc*i*
alias: pci:v00008086d00001574sv*sd*bc*sc*i*
alias: pci:v00008086d00001572sv*sd*bc*sc*i*
depends: ptp,vxlan
vermagic: 4.4.0-31-generic SMP mod_unload modversions
parm: debug:Debug level (0=none,...,16=all) (int)
output for ethtool enp8s0f1
 Settings for enp8s0f1:
Supported ports: [ ]
Supported link modes: 40000baseCR4/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Advertised link modes: 40000baseCR4/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Speed: Unknown!
Duplex: Unknown! (255)
Port: Other
PHYAD: 0
Transceiver: external
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Current message level: 0x0000000f (15)
drv probe link timer
Link detected: no
Amit
25 Antworten
Mike_Intel
1.195Aufrufe
Hello apapr,
I just want to check if you already logged a request with your local warranty team?
If you have questions, please let us know.
Michael L.
Intel Customer Support
Under Contract to Intel Corporation
Mike_Intel
1.195Aufrufe
Hello apapr,
Just sending another note to check if you already requested a replacement with your local support team.
Michael L.
apapr
Einsteiger
1.195Aufrufe
Not yet sent that for replacement. What reason I have to mention while replacement? Can it be done on other country from where it had been procured?
Mike_Intel
1.195Aufrufe
Hello apapr,
You may report the same fault description that you provided here. Every country has its own warranty team for them to assist you check the issue, validate the markings and drop an order.
Michael L.
Mike_Intel
1.195Aufrufe
Hello apapr,
Just want to check if you already contacted your local warranty team regarding issue.
Michael L.
Antworten
