[root@l2dev5g test-pmd]# ethtool --config-ntuple p2p2 flow-type tcp4 src-ip 10.23.4.6 dst-ip 10.23.4.18 action 1
rmgr: Invalid RX class rules table size: Operation not supported
Cannot insert classification rule
This is the feature list supported by "p2p2"
[root@l2dev5g test-pmd]# ethtool --show-features p2p2
Features for p2p2:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: off [fixed]
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp6-segmentation: on
tx-tcp-mangleid-segmentation: off
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: on
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: off [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: on
tx-ipip-segmentation: on
tx-sit-segmentation: on
tx-udp_tnl-segmentation: on
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: on
rx-vlan-stag-hw-parse: on
rx-vlan-stag-filter: off [fixed]
busy-poll: off [fixed]
tx-gre-csum-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-sctp-segmentation: off [fixed]
rx-gro-hw: on
l2-fwd-offload: off [fixed]
hw-tc-offload: on
rx-udp_tunnel-port-offload: on
Following are the network devices in my machine
[root@l2dev5g usertools]# ./dpdk-devbind.py --status-dev net
Network devices using DPDK-compatible driver
<none>
Network devices using kernel driver
0000:04:00.0 'NetXtreme BCM5720 2-port Gigabit Ethernet PCIe 165f' if=em1 drv=tg3 unused=igb_uio,vfio-pci,uio_pci_generic *Active*
0000:04:00.1 'NetXtreme BCM5720 2-port Gigabit Ethernet PCIe 165f' if=em2 drv=tg3 unused=igb_uio,vfio-pci,uio_pci_generic
0000:3b:00.0 'BCM57412 NetXtreme-E 10Gb RDMA Ethernet Controller 16d6' if=p2p1 drv=bnxt_en unused=igb_uio,vfio-pci,uio_pci_generic
0000:3b:00.1 'BCM57412 NetXtreme-E 10Gb RDMA Ethernet Controller 16d6' if=p2p2 drv=bnxt_en unused=igb_uio,vfio-pci,uio_pci_generic *Active*
Other Network devices
<none>
Hello PKomp,
Regarding your inquiry, kindly open the link below on how you can access DPDK support.
Click the "Login and Access" to contact the DPDK support.
https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
Hello PKomp,
I just want to check if you were able to contact our DPDK support for further assistance.
Michael L.
Hello PKomp,
I understand, however the customer is the one who needs to access and request for DPDK support.
If you have issues, please contact the email under login issues on the link below:
https://www.intel.com/content/www/us/en/design/support/ips/training/access-and-login.html
Michael L.
Hello PKomp,
Just want to check if you already contacted our DPDK support.
Michael L.
Hello PKomp,
I am just sending another follow up on the information that I requested.
Since we have not heard back from you, I will close this inquiry now.
Michael L.
