Ethernet Products
4873 Discussions
I have problems with my i225-V
XioX
I have problems with my ASUS ROG STRIX B550-F GAMING WI-FI motherboard, since the i225-v motherboard tells me "Unidentified network" and I tried to use the same cable on another pc and it works. Also I tried to update drivers, bios (from the motherboard) and it didn't work either. Can you tell me how to solve this problem? Thank you.
Greetings
Caguicla_Intel
Hello XioX,
Kindly provide the following information that would help in checking your request.
1. When was the issue first encountered?
2. Is the i225-V known to be working fine before?
3. Is there any software or hardware changes prior to issue?
4. Can you confirm if you already tried the steps from link below?
Network Issues with Intel® Ethernet Controller I225-V
https://www.intel.com/content/www/us/en/support/articles/000057261/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel® Customer Support
Caguicla_Intel
Hello XioX,
Crisselle C.
XioX
Hi, I tried a category 6 cable and it worked.
Thank you
Greetings
Caguicla_Intel
Hello XioX,
Thank you for the update.
We are glad to hear the the issue has been resolved after using Cat6 cable.
Please be informed that we will now close this request since you already marked the thread as closed. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Have a good day and stay safe!
Crisselle Franz
Intel Customer Support
