Ethernet Products
5530 Discussions
I just updated windows to 1809 hoping it would fix my ethernet not working and im still having the same problem even after clearing cmos .
PCast12
ill post a pictures to show the issue
 code 10
Device PCI\VEN_8086&DEV_15BC&SUBSYS_E0001458&REV_10\3&11583659&0&FE requires further installation.
system spec.
intel i7 9700k 5.1ghz 1.350v
gigabyte z390 master
corsair vengeance pro 16gb 3200
Samsung nvme m.2 500gb 970 evo boot drive
Samsung 870 ssd 256gb
4tb Seagate barracuda
2 1tb wd black hhd
evga 2080 ftw3
corsair 360 aio
evga 750 g3
Caguicla_Intel
Hello PCast12, Thank you for posting in Intel Ethernet Communities. Kindly provide the details below for us to check on your query. 1.) Did you install a new device or make a change in Device Manager just before the Code 10 error appeared? 2.) What is the Ethernet driver version installed on your system? 3.) Have you tried updating or reinstalling the Ethernet driver? 4.) Is the Ethernet working fine before or from the beginning it gives a code 10 error? Looking froward to your response. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello PCast12, Kindly provide the requested information for us to check on your query. We look forward to hear from you. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello PCast12, We would highly appreciate if you can share the details that we requested. This would help us to check on your query. Looking forward to your response. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
