Ethernet Products
5612 Discussions
I'm currently experiencing network jitter issues with an I226-V NIC.
if
My computer configuration is as follows:
CPU: 13 Generation 13900K
Motherboard: ROG MAXIMUS Z790 EXTREME
I posted a longer video on bilibili to illustrate, the network jitter issue. I think it's a very serious problem.
I would like to get the official stable I226-V NIC driver from intel.
Currently only Windows 10 systems will have, the network jitter issue.
Tested, WIndows1 doesn't have the network jitter problem.
https://www.bilibili.com/video/BV1SN41187pX/
B_Y
Hello @if,
Kindly provide the following information for us to check on your issue.
1.) System Support Utility(SSU) log of your system. This will allow us to check your Adapter details and configuration. This would also help us identify if you are using an OEM or retail version of Intel Ethernet Adapter. Kindly refer to the steps below.
a- Go to https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600 and download the software.
b- Open SSU.exe
c- Mark the box "Everything" and then click "Scan".
d- When finished scanning, click "Next".
e- Click on "Save" and attach the file to a post.
2.) When the issue started happening?
3.) Any software or hardware changes happened recently?
BY_Intel
Intel Customer Support
if
Thank you very much for your enthusiastic reply.
There have been many problems but I couldn't stand the pain of the Windows 10 I226 network drive any longer and I have replaced it with Windows 11 which is now running fine.
The following configuration information, I scanned in Windows 11.
B_Y
Hello @if,
Thank you for sharing the log and information.
Please be informed that I can only support you in English. I have used a web translation tool to translate some info from https://www.bilibili.com/video/BV1SN41187pX/, there may be some inaccurate translation.
1) May I know if you were testing the continuous pings rate for each refresh with different settings of I226-V from device manager in windows 10? May I seek your help to elaborate the contents and settings in English for better understanding.
- Intel has recently update with the latest Intel® Ethernet Adapter Complete Driver Pack 28.2: https://www.intel.com/content/www/us/en/download/15084/785512/intel-ethernet-adapter-complete-driver-pack.html?cache=1691188226
- Since the Intel® Ethernet Controller I226-V is embedded on Original Equipment Manufacturer (OEM) / Asus system, it's best to check with the manufacturer as the software drivers linked from Intel page are generic versions, and can be used for general purposes. To avoid any potential installation incompatibilities on OEM system, Intel recommends checking with the OEM and use the software provided via system manufacturer.
2) Based on the log given by you, which in Windows 11 and doesn't have the network jitter problem. It has latest driver: 2.1.3.15 for Intel® Ethernet Controller I226-V. May I ask where you get this driver from or how you update it?
BY_Intel
if
I have tested both the I226 and the Marvell AQtion 10Gbit network drives and they are the same performers.
I'm not sure if it's a problem with the network drive, or the motherboard, or the system, but anyway, what's happening now I'm reacting in windows as well. The motherboard manufacturer also reacted. Including the intel forums now I have responded to all of them as well
B_Y
Hello @if,
I hope this message finds you well. As previously noted, you ran some tests and found that the network jitter issue only affected Windows 10, whereas Windows 11 was free of the issue. The latest driver: 2.1.3.15 from your system most likely fix the issue with latest embedded configuration.
From the Asus' forum <https://rog-forum.asus.com/t5/intel-700-600-series/drivers-intel-ethernet-wifi-bluetooth/td-p/878985> : The latest Drivers - I225/I226 - Windows 11 : 2.1.3.15 WHQL [29/06/2023].
Please let me know if I can be of any assistance.
BY_Intel
if
@B_Y
I am using Intel(R) Network Connections Software Version 28.2 Release
The latest version of the I226-V driver is the same as the website you posted.
B_Y
Hello @if,
The latest drive or fix from OEM and Intel® Ethernet Adapter Complete Driver Pack have mainly fix the I225-V and I226-V issue on Windows 11 platform.
Please let me know if i can be of further assistance.
BY_Intel
if
@B_Y
I'm using the latest one, and the latest version 28.2 doesn't solve my current problem.
B_Y
Hello @if,
To help us understand your intentions properly, please provide more details about your existing testing setup.
Please supply the link and mention the driver you used. Since Windows 10 is the primary platform where the problem was found, you should update all drivers supporting Windows 10 in addition to the Asus driver listed above.
Important note: Since the Intel® Ethernet Controller I226-V is embedded on Original Equipment Manufacturer (OEM) / Asus system, it's best to check with the manufacturer as the software drivers linked from Intel page are generic versions, and can be used for general purposes. To avoid any potential installation incompatibilities on OEM system, Intel recommends checking with the OEM and use the software provided via system manufacturer.
BY_Intel
B_Y
Hello @if,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know. Thank you.
BY_Intel
B_Y
Hello @if,
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
BY_Intel
if
@B_Y
No response from the motherboard manufacturer and I've given up on resolving this issue
B_Y
Hello @if,
Noted on this and apologize that we can't provide accurate resolution of I226-V embedded on OEM system.
Intel recently released the Intel® Ethernet Adapter Complete Driver Pack, which was published to download center as of 08/25/2023.
Release Notification for Download Center: Release 28.2.1:
  • Release 28.2.1 ( Linux ICE driver with customer PTP fixes and certifying I40EB for W11 to address Release 28.2 exception EXC2331005) - Updated on Download Center
From Asus forum: https://rog-forum.asus.com/t5/downloads-for-motherboards/drivers-intel-ethernet-wifi-bluetooth/td-p/878985
Latest  Drivers - I225/I226 - Windows 10 : 1.1.4.42 WHQL [29/06/2023]
  • Download - I225/I226 - Windows 10Link
Again, we apologize to cause any inconvenience. Please do let us know if you have any further inquiries on this thread.
BY_Intel
B_Y
Hello @if,
Please be informed that we will now close this request since the Intel® Ethernet Controller I226-V is embedded on Original Equipment Manufacturer (OEM) / Asus system. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
BY_Intel
