Ethernet Products
5741 Discussions
I want to install shared storage use fcoe on two sersers,the adapter is intel x520-DA2. I use command''dcbtool sc p6p1 app:0 e:1" on diffrent server,when using "fcoeadm -i p6p2.1002-fcoe" to scan the status of port name and node name,get the same value.ho
bben
# first server
root@sdb-1 ~]# fcoeadm -i p6p2.1002-fcoe
Description: 82599ES 10-Gigabit SFI/SFP+ Network Connection
Revision: 01
Manufacturer: Intel Corporation
Serial Number: 90E2BA26EE3E
Driver: ixgbe 3.21.2
Number of Ports: 1
Symbolic Name: fcoe v0.1 over p6p2.1002-fcoe
OS Device Name: host11
Node Name: 0x1000001B2194DC83
Port Name: 0x2000001B2194DC83
FabricName: 0x100050EB1AF120AC
Speed: 10 Gbit
Supported Speed: 1 Gbit, 10 Gbit
MaxFrameSize: 2048
FC-ID (Port ID): 0x050000
State: Online
# second server
[root@dct1 ~]# fcoeadm -i p6p2.1002-fcoe
Revision: 01
Serial Number: 90E2BA0DE616
Number of Ports: 1
FabricName: 0x0000000000000000
Speed: 10 Gbit
MaxFrameSize: 2048
FC-ID (Port ID): 0x000000
State: Linkdown
st4
New Contributor III
Hi Fieldben,
Thank you for the post. Can you help clarify if you are referring two different X520-DA2 here on separate server? Is there any way you can get the complete serial # of both network adapters?
The serial number can be found on the white sticker on the NIC (90E2BA0DE616 + 5 digits + 6 digits - 3 digits) Thanks.
Are both network adapters connecting to the same switch ?
Rgds,
wb
Hi Fieldben,
Please feel free to provide the information
Rgds,
wb
bben
I am installing oracle RAC system,it include two servers that use shared storage.I use CNA connect to SAN instead of HBA.The switch is brocade VDX6740.When servers connected to switch,it can not distinguish two CNA.
Hi Fieldben,
Thank you for the information. I will further check.
rgds,
wb
Hi Fieldben,
Good day. Please help provide below information for better investigation:
1. dmesg log from both servers.
2.
"ifconifg -a" output from both servers.
3.
"flogi database" output from Brocade switch.
Please try latest driver version 4.4.6 to see if problem persist? Latest driver is available https://downloadcenter.intel.com/download/14687/Network-Adapter-Driver-for-PCI-E-Intel-10-Gigabit-Ethernet-Network-Connections-under-Linux-
Please feel free to update me. Thanks.
Rgds,
wb
Hi Fieldben,
Please feel free to provide the information.
Rgds,
wb
