Ethernet Products
5779 Discussions
I work on intel WG 82583 and I have problem to program falsh memory
I work on WG 82583. When I install the drivers the PC detects a intel 82574 and an error code 10 appears on the device manager.
In my flash of the 82583, I have nothing.
What is the procedure to update an image on flash ?
st4
New Contributor III
Hi BEN87,
Thank you for the post. If you are referring to updating the bootagent on the 82574 ethernet controller (onboard NIC), the boot agent must be updated as part of a BIOS update, what you can do is to contact your system vendor for information. If you are using a discrete network adapter, you may refer to this website about updating the bootagent:http://www.intel.com/support/network/adapter/pro100/bootagent/sb/cs-008362.htm Intel® Boot Agent — How to Update Intel® Boot Agent
rgds,
wb
No, I have a board with an intel 82583 via PCIe. When I start my board, I see on the device manager an intel 82574 and not a 82583.
I have a flash memory but not programming. I haven't got the procedure to program the fash and the file to program.
st4
New Contributor III
Hi BEN87, the 82583 is a ethernet controller , what is the exact board model?
wb
