Ethernet Products
5776 Discussions
I would like to know how to create an untagged vlan. I have 1809 fresh install with driver version 23.5(The latest). What script do I need inorder to create an untagged VLAN. I need to create a VLAN 2(Untagged) which will be my native Vlan
User1574365893941150
Caguicla_Intel
Hello User15743658939411501992,
Please share the exact model of your adapter.
Currently, Team and VLAN configuration are only supported using Intel® PROSet for Windows PowerShell* Software's cmdlets. This only applies to Windows® 10 Version 1809 (and later). Please refer to the steps below on how to create untagged VLAN as well as tagged using Powershell.
1. Open Windows Powershell as administrator.
2. Import the PROSet Powershell* module using this command: Import-Module -Name "C:\Program Files\Intel\Wired Networking\IntelNetCmdlets\IntelNetCmdlets"
3. Type "Get-IntelNetAdapter" to display the name of your network adapter.
4. Type "Add-IntelNetVLAN" to initiate the creation of a VLAN.
5. PowerShell will prompt for VLAN ID
To create an untagged VLAN, type VLAN ID = 0
For tagged VLAN, type the desired VLAN ID.
For example: VLAN ID = 9
When prompted for "ParentName", you can use the name of your network adapter from the "Get-IntelNetAdapter" output.
You may visit this link for Intel® PROSet for Windows PowerShell* Software
https://www.intel.com/content/www/us/en/support/articles/000023545/network-and-io.html
I hope that the information above would be helpful to you. In case you have additional questions and clarifications on this matter, please let us know.
Awaiting to your response.
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
Caguicla_Intel
Crisselle C
Caguicla_Intel
Good day!
Please provide the requested information for us to further check on your query. Please also share if you have tried to create/add VLAN using the steps above and what is the result after doing so.
Looking forward to hear from you.
Crisselle C
Caguicla_Intel
How are you today?
Please be informed that we will now proceed in closing this request since we haven't received any response from our previous follow up. In case there is any other inquiry that you may have in the future, please do not hesitate to post a new question.
Crisselle C
Caguicla_Intel
Thank you for the update.
We are glad to hear that the solution worked. Please be informed that we will now proceed in closing this request. Should you have any other concerns or assistance needed in the future, feel free to post a new question.
May you have a great day!
Crisselle C
