Ethernet Products
5776 Discussions
I210 Ethernet controller
DAndr14
I am engineering LAN with i210 ETH controller. I found out that Pull-up/Pull-down resistors Table have symbols Y and N which I do not understand what they mean. Could you help?
Hi LoginPlus,
Thank you for posting in Wired Communities. The "Y" refers to "Yes" which means you need to connect to external pull-up resistor. "N" refers to "No".
For further clarification, you can post your inquiry to the embedded support communities at
https://embedded.communities.intel.com/message/11275
Hope the above help.
Sharon T
Hi LoginPlus,
Sharon T
Hi LoginPlus,
Please do let me know if you still have other inquiries. Thank you.
Sharon T
