we have an issue about the I210-IS, when we set the PCIE root port to "disable", the speed LED and active LED will light up.
when set it to "enable", and there was no link, the LEDs will go out.
We co-lay I210-AT and I210-IS on the schematic, and when mount I210-AT,there was no this issue.
Could you please check whether it is related to the EEPROM or not?
Our EEPROM version is 3.25
Vicky
- Tags:
- PCIe
Hi MCDP2800,
Thank you for posting in Wired Communities. With regards to your inquiry, you may post at our embedded support for them to better assist you.
https://embedded.communities.intel.com/community/en
Sharon T
