Ethernet Products
5780 Discussions
I210-T1 / I350-T2 power consumption?
MGlas1
i want to know the power consumption of the I210-T1 and I350-T2 adapters cause I'm not sure
if it's right what the datasheed says.
Intel writes 0.81 Watt for the "Intel Ethernet Server Adapter I210-T1" but the "Intel Ethernet Server Adapter I350-T2" needs 4.40 Watt?
And then there is from HP the "E0X95AA Intel Ethernet I210-T1 GbE" where HP writes 3.00 Watt.
I believe the Intel and HP cards are nearly the same, so why that big difference.
Also i can use 5 "Intel Ethernet Server Adapter I210-T1" and still have lower power consumption then with 1 I350-T2?
VincentT_T_Intel
Hi MrGlasspoole, still confirming with Intel engineer on this item, i'll update this thread once available. thanks.
MGlas1
Hi Vince,
thanks for the feedback.
I thought there will never be an answer. But with todays electricity pricing here in Germany it makes a difference on a 24/7 machine.
VincentT_T_Intel
Hi MrGlasspoole, confirmation should be available soon.
MGlas1
st4
New Contributor III
Hi MrGlasspole,
We have confirmed 0.81W is the power consumption of i210-T1 card. Hope this helps.
thanks,
wb
MGlas1
The question was more if a i350-T2 really needs 4.40 Watt.
If so that means i can use 5 i210-T1 and the power consumption is less then with just one i350-T2?
5 Ethernet connections = 4 Watt
2 Ethernet connections = 4.4 Watt
MGlas1
Thanks wb_Intel,
thats what I'm talking about. I really wonder about the high power consumption of the i350-T2.
Especially now that you confirmed that the i210 really needs just 0.81 Watts.
st4
New Contributor III
Hi Mr. Glasspoole,
Yes. The i210T uses less power as compared to i350-T2.
rgds,
wb
RBoob
Is I210-T1 and I210 are same?
Shall we use the same UEFI driver for both I210-T1 and I210
Ram
st4
New Contributor III
Hi RamachandraB,
I210-T1 is the gigabit server adapter (which is the NIC you can install and remove from the system), you may refer to
ARK | Intel® Ethernet Server Adapter I210-T1
While I210 refers to the ethernet controller which refers to onboard NIC. http://ark.intel.com/products/family/2469/Intel-Gigabit-Ethernet-Network-Connection Intel® Gigabit Ethernet Network Connection
They are using the same driver
