Hi Team,
I am using the part #WGI210IT in my design. I have supplied 3.3V to the system, and the WGI210IT has generated internal voltages of 1.5V and 0.9V. However, instead of seeing a clock signal at the XTAL1 and XTAL2 pins, I am observing a high value around 700mV. According to the datasheet, the clock should be generated immediately after power-up. Could you please confirm if there are any other points I should check here? The DEV_OFF# pin is tied to 3.3V through a 10kΩ resistor, and the LAN_PWR_GOOD pin is also tied to 3.3V with a 10kΩ resistor, which should select the internal POR mode. Can anyone assist in identifying the issue?
Hi Shabeerali,
Greetings!
Thank you for posting in Intel community forum.
Kindly confirm the system information you are using so we can assist further.
Sreelakshmi
Hi Shabeerali,
Greetings!
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
Sreelakshmi
Hi Shabeerali,
Greetings!
We would like to inform you that we are closing this request as no response has been received from our previous follow-ups.
Please don't hesitate to ask any further questions in the future. Feel free to start a new conversation, as this thread will no longer be monitored.
Sreelakshmi
