Ethernet Products
5212 Discussions
I210 customer board linux driver
netkerlQuevedoyat
Request a driver for Linux. Installing Linux driver (igb-5.14.16) Please inquire about solutions to errors such as those in the attached file. thank you
Irwan_Intel
Hello netkerlQuevedoyat,
Thank you for posting to the Intel Ethernet Community.
Upon checking the attached file, it appears that the driver is likely missing the signing key.
Please try using the driver provided in the link below:
This release includes RPM packages that contain:
* Device driver signed with Intel's private key in precompiled kernel module
form
* RDMA driver
* Complete source code for above drivers
* Intel's public key
https://www.intel.com/content/www/us/en/download/14098/intel-network-adapter-driver-for-82575-6-82580-i350-and-i210-211-based-gigabit-network-connections-for-linux.html?wapkw=i211
Irwan_Intel
netkerlQuevedoyat
Hi, Irwn_Intel,
I am implementing 4 Giga Ethernet using 4 I210 chips as shown in the picture below. The previous H/W was configured with the same structure as the development structure below, with only the CPU (Module) part changed to Jetson Orin. The previous structure used Windows OS, and the structure below is implemented with Linux OS.
The I210 operated normally in the Windows OS environment, but in the H/W of the Linux environment, there is no clock buffer driver source, so I want to use a clock buffer that does not require a driver. Please introduce the recommendation chip for the clock buffer.
thank you
Regard,
Shane
Irwan_Intel
I'm following up to check if you have any additional questions or concerns at this time. Additionally, I'd like to confirm whether you were able to successfully download the drivers that was shared in the previous post.
Please let me know if you need any further assistance.
Irwan_Intel
Irwan_Intel
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Irwan_Intel
