We use Springville I210 ethernet controller, test Ethernet 100BASE-TX find failed item on "UTP +Vout Differential Output Voltage"
Did anyone have any suggestion to tune it or to solve it?
Fail item:
Test
Measure Value
Result
Output Voltage(+Vout)
950mV to 1050mV
1.0654 V
Fail
Output Voltage(-Vout)
-950mV to -1050mV
-1.0867 V
Fail
Many thanks!
Hi AlexHC,
Thank you for posting in Wired Communities. You may refer to the i210 FAQ below regarding the voltage information, please post your inquiry to our embedded support forum for them to better assist you.
https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq....
https://embedded.communities.intel.com/community/en
Sharon
