Ethernet Products
5566 Discussions
I217-LM and I210-IT Link aggregation
VBERT2
Do the I217-LM and the I210-IT support link aggregation (IEEE 802.3ad) ?
It seems that chips built on AMT technology do not support link aggregation:
st4
New Contributor III
Hi ValentiB,
Teaming is not supported if Intel AMT is present. I217-LM supports teaming and just to double check if you are referring to Intel I210-T1 server adapter? If yes, then this model support teaming.
wb
VBERT2
Hi wb,
I'm referring to the Intel I210-IT : http://ark.intel.com/products/64402/Intel-Ethernet-Controller-I210-IT Intel® Ethernet Controller I210-IT Specifications
Here is the configuration:
Is the link aggregation possible with this Ethernet controller too ?
st4
New Contributor III
Hi ValentinB,
If the ethernet controller is for server adapter and supports teaming, it can support link aggregation.
rgds,
wb
