Ethernet Products
5603 Discussions
I217 support removed from the UEFI Ethernet Driver
I tried using the 20.7 UEFI Ethernet Driver E7006X3.EFI, but I see that I217 support has been removed. Why?
I need I217-LM support in this driver.
Going back I see the last time it was in the Driver was version 20.0, E6604X3.EFI.
Can I217 support please be added back into future builds?
Thank You
SYeo3
Valued Contributor I
Hi Yahoo,
Thanks for contacting Intel. I'll check on this.
Sincerely,
Sandy
Hi Sandy:
Any updates? It's been a week.
Thank You
Been over a couple of weeks.... feedback, please?
Thank You
Hi, sorry for taking some time, we're still checking the concern. Please share to us the error you've encountered with E7006X3.EFI when using on i217-LM. Thanks.
regards,
Vince
Hi Vince:
Since there is no I217 support in the UEFI Driver, you cannot make use of the I217 during preboot, like at the UEFI Shell. You cannot do any networking at the UEFI Shell thru that port since the driver is ignoring the port.
So the failure is that the Ethernet port is simply "not there", whereas before we could see it and could do preboot networking to it (in the UEFI world).
-- Bob
Hi Bob, please download the latest driver package version 21 from our download center link below:
https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Connections-CD
The UEFI driver for i217 should be in the E0013X7.EFI located in APPS\EFI\EFIx64
Vince
Hi Vince:
I see that the support seems to have been moved into a different driver.
From the Driver Download page I see this:
PREBOOT\APPS\EFI\ Extensible Firmware Interface (EFI) drivers and files
..\DOCS\ User guide files for EFI
..\EFI64\EnnnnI4.EFI - UEFI IA64 10 gigabit driver (nnnn = version)
..\EFI64\EnnnnI2.EFI - UEFI IA64 PCI gigabit driver (nnnn = version)
..\EFI64\EnnnnI3.EFI - UEFI IA64 PCI-E gigabit driver (nnnn = version)
..\EFIx64\EnnnnX4.EFI - UEFI x64 10 gigabit driver (nnnn = version)
..\EFIx64\EnnnnX2.EFI - UEFI x64 PCI gigabit driver (nnnn = version)
..\EFIx64\EnnnnX3.EFI - UEFI x64 PCI-E gigabit driver (nnnn = version)
But, I don't see what Drivers of the format EnnnnX5.EFI or EnnnnX7.EFI are?
Can you please fill in the table for what Drivers of the form ExxxxX5.EFI and EnnnnX7.EFI are for?
Thank You
Hi Yahoo,
Sharing the exact version indicated in the file.
EFI64\E1815I5.EFI
EFI64\E5314I4.EFI
EFI64\E3522I2.EFI
EFI64\E7107I3.EFI
EFIx64\E0013X7.EFI
EFIx64\E1815X5.EFI
EFIx64\E5314X4.EFI
EFIx64\E3522X2.EFI
EFIx64\E7107X3.EFI
Vince
Vince:
You did not understand me.
Please fill in the missing ????? lines below with the correct type of driver.
..\EFIx64\E3522X2.EFI - UEFI x64 PCI gigabit driver
..\EFIx64\E7107X3.EFI - UEFI x64 PCI-E gigabit driver
..\EFIx64\E5314X4.EFI - UEFI x64 10 gigabit driver
..\EFIx64\E1815X5.EFI - UEFI x64 ????? driver
..\EFIx64\E0013X7.EFI - UEFI x64 ????? driver
Thank You
Hi Yahoo,
I'm currently checking for the requested information, will update this thread as soon as possible.
regards,
Vince
Hi Yahoo,
x5 is for 40gb
all Intel PHY products 82579/ I217/ I218/ I219 should use x7.
regards,
Vince
Vince:
I need I210 and I217 support in the same driver. Which one is supposed to support that?
Thank You.
Hi Yahoo, based on the description, if your i210 and i217 are ethernet controller built-in to the system board, E0013X7.EFI should be the required driver. Let me confirm this and update this thread as soon as possible.
Vince
Hi Vince,
Yes, the I210 and I217 are ethernet controller built-in to the system board.
With the E0013X7.EFI driver I can now use the I217; however, I can not use the I210.
We need support for BOTH of these devices in the same driver (as was the case in drivers earlier than 20.0).
Thank You.
Hi Yahoo,
We will have to build the driver for i210 support. What is it that you were trying to accomplish with EFI support?
Sincerely,
Sandy
Hi Sandy:
I don't really understand the question....isn't it somewhat obvious?
I have a system that has I210 and I217 onboard. We use UEFI for our firmware. Out customers use FTP in the pre-boot space using the UEFI Network stack to accomplish this. We also do UEFI PXE boot.
This support "used to be built-in", until 20.0. Why did that have to change?
We have various other boards with other Intel Ethernet controllers onboard. Some of these are the X552, XL-710, and 82599. Can you please see if these would also be supported (by the same driver)? I think the XL-710 might not be able to be; but support for the others would be most helpful.
Thank You.
Hello Yahoo,
Thank you for your information. We'll check on the available drivers for the built-in adapters and will update you on our findings.
Sincerely,
Sandy
Dear Bob,
If you have the adapter's driver version 21.0, please use the EFI driver below:
...\APPS\EFI\EFIx64\E7107X3.EFI
The changes in the UEFI driver supported adapters are due to the driver updates wherein some features are either added or removed.
Hope this help fix the issue.
Sincerely,
Sandy
Sandy:
It has been over 2 months since I submitted this question, and we are no further along now.
This image, the E7107X3.EFI from release 21.0, does NOT have I217 support built in!
As I mentioned before, I need I217 and I210 (and likely others) built into the same .EFI file (as these Ethernet devices are on my companies mainboard).
Can you please work with the people in your company to restore this functionality?
Thank You
Dear Bob,
I see you have tried the above-mentioned image already. I'll further check on this.
Sincerely,
Sandy
