Ethernet Products
5823 Discussions
I217V on Z87 Motherboard Hangs with e1000e Linux Driver until Clear CMOS
ASosn
I built a Linux machine around an ASROCK Z87 Extreme4/TB Motherboard with an onboard I217V Ethernet port.
Behavior is the same on recent Mint/Ubuntu and Fedora distributions with up to date e1000e drivers.
On booting from a clean state the Ethernet port is recognized and seems to work fine.
Once I do nearly any sort of shutdown, suspend, or restart the port is hung on reboot or resume.
The port remains hung even after a complete power cycle and reboot. The port remains hung after
entering UEFI BIOS and reloading all UEFI defaults. Opening the case and physically clearing CMOS resets
the port to a working state.
Can anyone help? Is there any sort of linux utility that would allow me to reset the port? Opening the case every time I need to reboot is a major pain.
lspci output follows. If anyone can help, let me know what other output or information would be useful.
lspci -vvx -nn -d8086:153b
00:19.0 Ethernet controller [0200]: Intel Corporation Ethernet Connection I217-V [8086:153b] (rev 05)
Subsystem: ASRock Incorporation Device [1849:153b]
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-   Latency: 0
Interrupt: pin A routed to IRQ 43
Region 0: Memory at dc500000 (32-bit, non-prefetchable) [size=128K]
Region 1: Memory at dc53d000 (32-bit, non-prefetchable) [size=4K]
Region 2: I/O ports at f080 [size=32]
Capabilities:
Kernel driver in use: e1000e
00: 86 80 3b 15 07 04 10 00 05 00 00 02 00 00 00 00
10: 00 00 50 dc 00 d0 53 dc 81 f0 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 3b 15
30: 00 00 00 00 c8 00 00 00 00 00 00 00 0a 01 00 00
