Hi all
Currently with the all available versions of the Windows 8.1 x64 I218-V you cannot use Wake On Lan if you have fastboot enabled, which is extremely painful.
Specs of system:
Operating System: Windows 8.1 Pro 64-bit
CPU: Intel Pentium G3420
RAM: 8.00GB DDR3 (9-9-9-27)
Motherboard: ASUS Z97M-PLUS
HDD: 500gb WD Black
This is a media pc, which really would make use of fastboot.
I've tried the drivers, all versions available, from the ASUS site:
Intel LAN Driver V12.11.96.1
Intel LAN Driver V19.0.27.0
This new driver from Intel site:
PROWinx64.exe 19.3
BIOS has correct settings to allow wake on lan.
Every single kind of power related setting imaginable to disable management on ALL devices, full power mode ahead. No joy.
No matter what options you use this horrendous set of drivers does not allow wake on lan with fast boot enabled, unlike every single realtek nic based mobo i've ever used.
I doubt that it will be fixed, or if Intel engineers even read these forums. But here's to hoping...
While it works without fast boot enabled, this is not a fixed. Merely a bandaid to the dodgy driver.
Hi Stasis, not sure if you've already tried this combination:
1. fast boot - enabled
2. network stack driver support - enabled (under the "Boot" option of Asus Z97M-Plus)
hope this helps.
regards,
Vince
Thanks for the response, I should have mentioned in my first post that I also tried doing what you've suggested and this does not work.
To clarify:
Enabling stack driver support under boot options and other options in BIOS does not resolve this issue.
thanks for the update, have you tried using a discreet network adapter to further isolate the issue? how'd you perform the magic packet thru magic packet?
Sent magic packet using router tool and through an android function I use daily which works fine with fastboot off, and works fine with fast boot on on every other device I have (this is the only Intel NIC I've unfortunately been stuck with)
I'm considering purchasing another NIC to bypass this issue, a bit ridiculous when Intel should resolve with a driver update.
Bump
Any intel engineers check these forums?
Hi Stasis,
Sorry for the delay. I got this from our engineers:
Instructions for Enabling WOL in FastStartup
**Currently Supported On: Intel® i217/i218 w/Clarkville SW6 PV Driver**
Following are the changes required, for Intel® PHY/LOM products, to support WOL in Fast Startup:
• Enable LOM driver by setting registry "WakeOnFastStartup" to 1
• View "ReadMe-WakeOnFastStartup.txt" to use theWakeOnFastStartup.bat file correctly
• Add a write in BIOS in IO space of ACPI, register GPE0a_EN in (Base address* + 0x28), set bit 13, PME_B0 Enable
**IO space base address of ACPI can be found in PCI device 31, Function 0, offset 0x40.
Additional Notes:
• After Enabling LOM driver by setting registry
"WakeOnFastStartup" to 1, the BIOS will set this bit whenever the system goes to S5 Fast Startup.
• System does not need to check for driver WOL setting because the driver will always configure WOL based on the above registry change
• If the user disables the WOL capability in the menu, no issues should occur since the driver won't configure any filter in the PHY.
• An external power supply to the LAN is required on FastStartup if WOL is enabled.
Rich
I have a very similar problem and am struggling implementing with rosiao's answer.
Specs of system:
Operating System: Windows 10 Pro 64-bit
CPU: Intel Core i5
RAM: 8.00GB DDR3
Motherboard: ASUS H97M-PLUS
SSD: INTEL SSDSC2CW180A
This is a office pc which needs to WOL for its nightly remote backup and I would really like it to "fast start-up".
I have the most up to date Intel LAN Driver V12.13.17.4
With "fast start-up" off WOL works perfectly. With "fast start-up" on WOL refuses to work.
I have tried to follow these instructions:
I have successfully setup the registry, but can not find "ReadMe-WakeOnFastStartup.txt" on the internet and do not understand how to "Add a write in BIOS in IO space of ACPI, register GPE0a_EN in (Base address* + 0x28), set bit 13, PME_B0 Enable". However, if I have understood "After Enabling LOM driver by setting registry "WakeOnFastStartup" to 1, the BIOS will set this bit whenever the system goes to S5 Fast Startup." correctly a reboot will cover the rest of the instructions.
I would be grateful for some help with this issue.
Many thanks,
theduck01
Same problem with
Intel(R) Ethernet Connection I219-LM
on Gigabyte Brix GB-BKi5(H)A-7200
Using driver 12.15.23.9
Intel(R) Ethernet Flash Firmware Utility
BootUtil version 1.6.39.1
Copyright (C) 2003-2017 Intel Corporation
Type BootUtil -? for help
Port Network Address Location Series WOL Flash Firmware Version
1 1C1B0DBC22F7 0:31.6 Gigabit N/A FLASH Not Present
Of course I read https://www.intel.co.uk/content/www/uk/en/support/network-and-i-o/ethernet-products/000005793.html https://www.intel.co.uk/content/www/uk/en/support/network-and-i-o/ethernet-products/000005793.html
I have set WakeOnFastStartup to "1" (enabled)
Brix BIOS F5 has very limited options
With Fast Startup DISABLED WoL works as expected
If I enable Fast Startup there is light on the card stays at Power Off, but WoL does NOT work!
So the only option is to disable Fast Startup (not ideal)
Anybody has any constructive ideas?
Seb
