Ethernet Products
5821 Discussions
I219-LM not sensing ethernet cable plug/unplug. Operating System is Windows 10.
VRoma11
Currently using driver updated by Windows. Here are specs on driver properties.
  • Driver Provider: Intel
  • Driver Date: 3/21/2017
  • Driver Version: 12.15.25.6
  • Digital Signer: Microsoft Windows Hardware Compatability Publisher
Sensing works with this driver but does not for many others including release version 24.1. Need to be able to identify literal driver for which cable plug/unplug is detected and re-identified as physically connected. Detection of cable plug/unplug is random for customers. Hope is i can point them to Intel site and state download this driver. Bad new is does not work for version 24.1.
AlHill
What version of Windows 10? 1903?
Doc
VRoma11
Version 1607, OS Build 14393.1770
AlHill
Before anything can be done, you have to upgrade Windows. you are THREE years out-of-date, and your version of W10 is not supported.
Go to https://www.microsoft.com/en-us/software-download/windows10, and upgrade.
Doc
VRoma11
I will upgrade and report back.
VRoma11
Windows 10 is now upgraded. We have two PCs being used for test.
PC 1: Windows 10 Pro version 1903 (Cable connect/disconnect and then reconnect . THIS WORKS)
I219-LM:
PC 2: Windows 10 Pro Version 1903 (Cable connect/disconnect and then reconnect. DOES NOT WORK)
I219-LM: Downloaded from Intel website version 24.1
However, I do not think it is just relegated to the newest drive. I originally observed the problem with a driver dated from 2015. I simply used Update Driver within Windows Device Manager and it grabbed the 3/21/2017 driver. Not sure what governs driver selection.
There seems to be some variable that is preventing identification of a cable connect. Truly appreciate your assistance in trying to determine.
Mike_Intel
Hello VRoma11,
We just want to check if you still need assistance for this issue.
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
Mike_Intel
Hello VRoma11,
I have not heard back from you so I will close this inquiry now.
If you need further assistance, please post a new question.
Michael L.
Ronniel_Aybar
Hola, Lamento no poder escribir en ingles esta respuesta.
He tenido en varias ocasiones este problema, y he estado probando con una solución que en algunos casos funcionan y en otros no, pero aun asi lo compartire para tener un campo más amplio de experimentación. Esta es la solución que he encontrado al problema; lo que hago es que desintalo los programas y los drivers que controla la tarjeta de ethernet (I219-LM) luego descargo los drivers desde este link y antes de instalarlos preparo un cable ethernet RJ45 Crossover y los conecto en la tarjeta de ethernet, entonces si instalo los drivers y se conecta al router obteniendo su Ip por DHCP.
Como le dije anteriormente no siempre me funciona, pero si le llega a funcionar denos su opinion para asi tener mayor experiencia.
