Ethernet Products
5570 Discussions
I219-V 差異與用途 ? 要如何選用 ?
AJ0820
WGI219LM 與 WGI219V P2P的料 ~~選用上的差異 ? 是否有文件可以參考
~~謝謝各位前輩指教 ~~
Mike_Intel
Hello AJ0820,
Thank you for the update. I have created a head to head comparison between the two cards and what I found our is Intel® Ethernet Connection I219-LM supports Intel vPro® Technology. Here is the link:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=82185,82186
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Mike_Intel
Hello AJ0820,
First of all, please be advised that we can only support you in English and we are just using our own translator tool to understand your inquiry. Please reply to us in English.
Before we proceed, can you further explain your inquiry? Are you buying WGI219 or are you designing a board or a system with WGI219 since you are asking for the files to use? Please give us more details for us to direct you and assist you further.
Michael L.
Mike_Intel
Hello AJ0820,
I hope you're having a wonderful day. I am just making a follow up on the information that we requested.
Michael L.
AJ0820
Dear Sir,
Thanks for your reply.
I am a component engineer (CE), and the company has bought WGI219-V & WG219-LM at the same time.
I want to know the difference between WGI219-V & WG219.
PS: Because I can’t see the difference from Datasheet
Mike_Intel
Hello AJ0820,
Michael L.
AJ0820
Thank you.
I have solved the problem.
Mike_Intel
Hello AJ0820,
Thank you so much for the update and confirmation. Since the issue is not resolved, we will close this thread and if you need assistance again the future, please don't hesitate to post a new question.
Thank you and stay safe.
Michael L.
