Ethernet Products
4628 Discussions
I219V High Propagation Delay
ASadi1
I have an https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC7i3BN_TechProdSpec.pdf Intel NUC7i3BNH with the I219V ethernet controller which is 802.1AS compliant according to its https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/ethernet-connection-i219-datasheet.pdf datasheet.
I am trying to use it with ptp4l and a gPTP profile but I get really high propagation delays in the range of 7μs when connected directly to an I210 device or Extreme x440-48t switch. This is very high for hardware timestamping. For reference, the I210 has a propagation delay of around 20ns when connected to the switch or another I210. The gPTP profile needs a propagation delay below 800ns to be considered AS capable.
I tried updating the e1000e drivers to version 3.4.1.1-NAPI but results were the same.
I am using Ubuntu 18.04.1 LTS and 4.13.0-45-generic kernel.
Why is the propagation delay so high and what can I do to fix it? Is the I219V actually 802.1AS compliant?
Thanx,
Andre.
Hi Andre,
Thank you for posting in Wired Ethernet Community.
Please share the output of your Ethtool -i.
Vince T.
Intel Customer Support
Agent under contract to Intel
ASadi1
Hi Vince,
Thank you for the response. I just updated my kernel to 4.18.1-041801-generic so some info is a little different from the original post, such as the driver version.
Ethtool -i:
driver: e1000e
version: 3.2.6-k
firmware-version: 0.1-4
expansion-rom-version:
bus-info: 0000:00:1f.6
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
Thank you,
Andre.
Hi Andre,
Thanks for providing the information, let me further check this issue and update this thread as soon as possible.
Vince T.
ASadi1
Hi Vince,
Thank you for looking into it. Please let me know if I can provide any further information.
Andre.
Hi Andre,
Please share detail steps on how you're testing the propagation delay. Also, have you tried it on different operating system?
Vince T.
ASadi1
Hi Vince,
I have not used any operating systems other than Ubuntu.
I have used Ubuntu 16.04 and 18.04.
Specifc kernels: 4.13.0-45-generic, 4.15.0-29-generic and 4.18.1-041801-generic
The I210 works fine on all the above.
Running the ptp4l (Linux PTP) module gives the propagation time between 2 devices. I am using the peer-delay mechanism as explained in the image below although E2E delay gives similar values.
Command used: sudo ptp4l -i eno1 -f gPTP.cfg -m
Short gPTP.cfg profile:
[global]
gmCapable 1
priority1 248
priority2 248
logAnnounceInterval 0
logSyncInterval -3
syncReceiptTimeout 3
neighborPropDelayThresh 800
min_neighbor_prop_delay -20000000
assume_two_step 1
path_trace_enabled 1
follow_up_info 1
transportSpecific 0x1
ptp_dst_mac 01:80:C2:00:00:0E
network_transport L2
delay_mechanism P2P
The propagation delay can also be observed from the Extreme x440-48t switch side.
X440-48t.14 # show network-clock gptp port 31
Physical port number : 31
gPTP port status : Enabled
Clock Identity : 00:04:96:ff:fe:9a:91:d2
gPTP Port Number : 31
IEEE 802.1AS Capable : No
Port Role : 3 (Disabled)
Announce Initial Interval : 0 (1.000 secs)
Announce Current Interval : 0 (1.000 secs)
Announce Receipt Timeout : 3
Sync Initial Interval : -3 (0.125 secs)
Sync Current Interval : -3 (0.125 secs)
Sync Receipt Timeout : 3
Sync Receipt Timeout Interval : N/A
Measuring Propagation Delay : Yes
Propagation Delay : 7287 ns
Propagation Delay Threshold : 800 ns (auto)
Propagation Delay Asymmetry : 0
Peer Delay Initial Interval : 0 (1.000 secs)
Peer Delay Current Interval : 0 (1.000 secs)
Peer Delay Allowed Lost Responses : 3
Neighbor Rate Ratio : 0.999978
PTP Version : 2
You can also see this thread https://sourceforge.net/p/linuxptp/mailman/message/36386718/ https://sourceforge.net/p/linuxptp/mailman/message/36386718/ for a discussion about the I219V propagation time from the ptp4l side.
Andre
Hi Andre,
Thank you for providing the information. We'll check further and update this thread as soon as possible.
Vince T.
ASadi1
Hi Vince,
Thank you for your time. Any update yet?
Thank you,
Andre.
Hi Andre,
We'd like to apologize for the delay, this issue is still being investigated.
Vince T.
Hi Andre,
Please try the driver version - 3.4.2.1. You may download the file from this https://sourceforge.net/projects/e1000/files/e1000e%20stable/3.4.2.1/ link.
Vince T.
ASadi1
Hi Vince,
Driver installed and the path delay is still the same.
ethtool -i:
driver: e1000e
version: 3.4.2.1-NAPI
firmware-version: 0.8-4
supports-test: yes
Hi Andre,
After further investigation, the I210-T1 would be better for your usage. The IEEE 1588 was not a design consideration for the NUC with I219-V and there's no configuration available to alter the propagation delay.
Vince T.
Hi Andre,
Please let us know if you have further clarification regarding your query. Thanks.
Vince T.
ASadi1
Hi Vince,
Thank you for the feedback.
I would like some clarification on why the NUC and I219-V specifications specifically state that they are 1588 compliant if it was not a design consideration? The main reason we purchased the NUCs is for their stated timestamping capabilities.
Andre.
Hi Andre,
Let me check this internally and update the thread as soon as possible.
Vince T.
VincentT_Intel
Hi Andre,
How are you?
Please be informed we're still looking into your query and will post update soon.
Vince
Under Contract to Intel Corporation
VincentT_Intel
Hi Andre,
Even though the I219-V has higher propagation delay compared with I210, it is still 1588 compliant. The I210 has a different design implementation compared to I219 that produces better propagation delay. We apologized for the inconvenience this issue had caused you.
Vince
VincentT_Intel
Hi Andre,
Please let us know if there's other assistance needed.
Vince
