Ethernet Products
5720 Discussions
I225-LMvP (rev 03) doesn't work in Linux 6.6.30, 6.9.0
AckoftOvak
It works in 6.1.90:
[ 4.540615] Intel(R) 2.5G Ethernet Linux Driver
[ 4.540618] Copyright(c) 2018 Intel Corporation.
[ 4.540649] igc 0000:57:00.0: enabling device (0000 -> 0002)
[ 4.555096] igc 0000:57:00.0: PTM enabled, 4ns granularity
[ 4.630720] igc 0000:57:00.0 (unnamed net_device) (uninitialized): PHC added
[ 4.655970] igc 0000:57:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[ 4.655975] igc 0000:57:00.0 eth0: MAC: 64:4b:f0:37:ea:fa
[ 5.021314] igc 0000:57:00.0 enp87s0: renamed from eth0
[ 8.644120] igc 0000:57:00.0 enp87s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 8.644430] IPv6: ADDRCONF(NETDEV_CHANGE): enp87s0: link becomes ready
In 6.9.0 I get:
[ 4.761673] Intel(R) 2.5G Ethernet Linux Driver
[ 4.761674] Copyright(c) 2018 Intel Corporation.
[ 4.761711] igc 0000:57:00.0: enabling device (0000 -> 0002)
[ 4.761861] igc 0000:57:00.0: PTM enabled, 4ns granularity
[ 4.824397] igc 0000:57:00.0 (unnamed net_device) (uninitialized): PHC added
[ 4.849489] igc 0000:57:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[ 4.849496] igc 0000:57:00.0 eth0: MAC: 64:4b:f0:37:ea:fa
[ 4.875851] igc 0000:57:00.0 enp87s0: renamed from eth0
[ 4.996687] igc 0000:57:00.0 enp87s0: PHC removed
[ 5.040245] igc 0000:57:00.0 enp87s0: PCIe link lost, device now detached
I tried adding "pcie_port_pm=off pcie_aspm.policy=performance" to the kernel parameters. It didn't help:
[ 4.975387] igc 0000:57:00.0: Unable to change power state from D3cold to D0, device inaccessible
[ 4.975586] igc 0000:57:00.0: PTM enabled, 4ns granularity
[ 4.975629] igc 0000:57:00.0 (unnamed net_device) (uninitialized): PCIe link lost, device now detached
[ 48.736676] igc 0000:57:00.0: probe with driver igc failed with error -13
Sazirah
Hi AckoftOvak,
Regarding this issue, kindly share the SSU logs for us to analyze at our end. You may refer link below:
Also, please assist on doing clean driver installation and install the latest driver pack version.
You may refer below for clean driver installation:
https://www.intel.com/content/www/us/en/support/articles/000058304/ethernet-products.html
Then, please install the latest driver pack version:
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
Sazzy_Intel
AckoftOvak
This link looks like an internal Intel Customer Support website. I am not an Intel employee, I don't have access.
What does this article have to do with Linux?
For this product, Intel integrates the driver right into the Linux kernel, there is no installation.
SSU log is attached.
Sazirah
Hi AckoftOvak,
Thank you for sharing the SSU logs.
We are currently checking on this and will get back to you soon.
Appreciate your cooperation on this.
Sazzy_Intel
n_scott_pearson
Regarding SSU, please download and run the Intel System Support Utility for Windows. When you start the utility, select Everything and then click on Scan. Once it completes the scan process, click on Next and then Save. Pick a name for the text file to create and click on Save to create it. You can then close the app. Finally, open a response post here and then, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
AckoftOvak
Attached. I am curious why do you need Windows information to solve a problem on Linux? FYI, after booting Windows this device doesn't work even on 6.1 kernel until a power cycle (reboot Linux, power off, boot Linux again). Sometimes I have to powercycle a couple of times before it starts working on Linux.
n_scott_pearson
This is the standard way to run it on Windows to get the most information possible. The Linux version (https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html) has different switches.
AckoftOvak
I tried kernel 6.8.9. It also doesn't work.
Sazirah
Hi AckoftOvak,
Regarding your enquiry, please take note that the linux kernel version that is supported and tested by Intel is 5.8 and 5.16.18. Please refer to article link below for the OS supported list for Intel Ethernet Controllers (LOM).
https://www.intel.com/content/www/us/en/support/articles/000055236/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
As per Intel, please only access the igc driver to the corresponding kernel version listed in the link.
If you would like to enquiry further on the compatibility of the linux kernel version that you are currently using, we advise you to contact the OS (linux) customer support to assist you further.
Sazzy_Intel
AckoftOvak
This sounds like I should avoid Intel products. Thank you.
P.S. Technically, either your answer is wrong or the article is wrong since the latest updates for Ubuntu 22.04 use a 6.5 kernel, but I understand what you are saying.
Sazirah
Hi AckoftOvak,
Thank you for your reply. My apologies on the inconveniences
As per the article, only those version is tested and supported for Intel Ethernet I225-LMvP. For any further enquiries related to the latest OS version, you may contact the OS technical support, they should be able to assist your regarding your enquiries.
Sazzy_Intel
AckoftOvak
You are welcome. I understood Intel's position from your previous message, so there was no need to repeat yourself. Lol.
Let me use this opportunity to correct your grammar mistakes.
Thank you for your reply. My apologies for the inconvenience.
As per the article, only those versions are tested and supported for Intel Ethernet I225-LMvP. If you have any further inquiries related to the latest OS version, you may contact OS technical support. They should be able to assist you.
Best.
AO.
Sazirah
Hi AckoftOvak,
I appreciate your keen eye of detail, thanks for catching that and I'll make sure to double check in the future.
Regarding your issue, do you have any other questions? If yes, please let us know and we will assist you.
Sazzy_Intel
AckoftOvak
Figuratively speaking, you've given me the finger, hiding it under corporate lip service. In what possible scenario would a person have any questions after that? You've told me to be off. This is what I am going to do, plus to avoid Intel products in the future. Or are you just mocking me? I am curious.
AckoftOvak
The solution was to add pcie_ports=native to the kernel parameters. I would like to thank Intel again for the fantastic customer support. With no other company but Intel, I feel like they care about customers and go out of their way to resolve issues. Thank you so much.
