We are using I226 in our custom board design, in the device we have RBIAS pin, as per recommendation we have 200 ohm between RBIAS pin and ground. Currently we have provided 0402 package 63mW resistor, we are doing stress analysis. Hence any voltage or current value we can get to calculate the stress across this resistor?
Thanks and Regards
Adarsh K Hegde
Hi AdarshKHegde,
Greetings for the day!
To proceed with this case, we recommend that you create a support ticket in the Intel® Premier Support portal using the following link:
http://premiersupport.intel.com/
If you are experiencing any additional issues or have further queries, please let us know. We are happy to assist you.
Akshaya
Hi AdarshKHegde,
As informed earlier, we recommend that you create a support ticket in the Intel® Premier Support portal to proceed with resolving your issue.
Please note that we will proceed with closing this request as it falls outside the scope of our support.
Akshaya
