Can I connect the I226 Ethernet Media Interface to a MaxLinear GPY215 in a Transformerless Ethernet Application (TLE)?
I have confirmed with MaxLinear that their PHY can communicate via TLE with decoupling caps (PNG attached). I want to confirm that the I226 can handle the decoupled signaling without being biased by a pull-up resistor.
Hello Nathan,
Greetings for the day!
Thank you for contacting Intel regarding your inquiry. We are actively working towards finding an appropriate resolution for your issue. To proceed further, I kindly request that you share the product details along with the front and back pictures of the controller and the system details on which the controller is installed.
Please feel free to respond to this email at your earliest convenience.
Amina
Hello Amina,
Can you elaborate on what you mean by "front and back pictures."
This controller is being used in a prototype product, the prototype is in the design stage and has not been fabricated. An isolation transformer can be added to the design if needed but ideally I would like to configure the UTP connection to work in a transformer-less application.
The I226-IT acts as a PCIe-Ethernet bridge. A common use-case for the product would be 2G of Ethernet video steam data coming into the IC on the Ethernet interface and relayed out through the PCIe interface to a CPU on a motherboard.
Hello Team,
Thank you for your response. As you are looking for information related to design files, schematics and related data, I recommend contacting Intel® Resource and Documentation Center (RDC) and/or Intel® Developer Zone (Intel® DevZone) for your query.
If you do not have an Intel® Resource and Documentation Center (RDC) and/or Intel® Developer Zone (Intel® DevZone) account, kindly refer to the link below. Please bear in mind that you will need a premier account with CNDA access in order to access the files.
Amina
Amina,
I have a Developer Zone Premier account. I originally posted this question in the Intel Developer Zone and I was directed to post my question here (Case #: 06428481).
Should I re-post this again in IDZ support?
Hi Team,
Thank you for the response.
Please feel free to reply to this email. We're here to assist you every step of the way.
Mohammed Ali
Intel Customer Support
Mohammed,
I have opened a case in the IDZ again (Case #: 06473609). If I am encouraged to reach "out to Embedded community for further assistance" I will be pointing them to this thread.
Hi Nathan,
Greetings of the day.
Please keep us posted.
So that we can proceed further accordingly.
Ali
Hello NB_ComNet,
I also design transformerless, does your approch work with the intel chip?
