Ethernet Products
5737 Discussions
I226-IT latest Linux Driver & TSN enable
bsp_user
We have a custom carrier board hosting a tiger lake CPU and I226-IT NIC.
We use Ubuntu 22.04 and need to demonstrate TSN capabilities.
We searched at the official product page
https://www.intel.com/content/www/us/en/products/sku/210591/-intel-ethernet-controller-i226it/specifications.html
but didn't find any TSN enable instructions in Linux Ubuntu.
1. Where to get the latest Linux driver for enabling the TSN capabilities?
2. Are there any additional operations required to enable the TSN capabilities? (Firmware update/tools install/etc)
3. We didn't find all the supported TSN capabilities and protocols for this NIC except for PTP. Where can we find the full list?
Sazirah
Hi bsp_user,
Regarding the issue reported, you may want to visit Intel Resource & Document Center (RDC) to find the related documentations. You may also want to check below link that explain TSN on Linux:
https://www.intel.com/content/www/us/en/secure/content-details/616446/ethernet-time-sensitive-networking-on-linux-for-intel-processors-ethernet-controller-i225-i226-get-started-guide.html?wapkw=tsn%20i226&DocID=616446
Hope this clarifies.
If you have any other questions, please let know.
Saazzy_Intel
Sazirah
Hi bsp_user,
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
bsp_user
Hi Sazirah,
I get an access denied error when following your link:
In addition, do you mind directing us to the suitable docs in rdc regarding how to enable and use the TSN capabilities on Linux (Ubuntu) for I226-IT
Thank you for your patience.
Subhashish
Hi bsp_user,
Greetings !!
The previous link was shared for the page. from same page, I am sharing you the direct download link for the file instead. Please check and see if this works:
https://cdrdv2.intel.com/v1/dl/getContent/616446?explicitVersion=true
Subhashish_Intel.
bsp_user
This link requires some intel related account to log in which i don't have. I'm sorry
Subhashish
Hello bsp_user,
Thank you for your confirmation. This would be because you do not have a premier access to Intel's Resource and Documentation Center (RDC). Intel RDC has two types of documents, one which is available to public and only a standard account is required to have to view/download it. Other one is Intel Confidential Document, not available to public directly and requires a premier account.
This document requires a privileged access. Please refer to below article which guides how to create RDC account - both standard and premier one. You will need the premier one-
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
This will guide you step by step with illustrated images of the set up/sign up process.
Subhashish
Sazirah
Hi bsp_user,
Greetings
I would like to follow up with you regarding this case.
Please be inform that the link to the documentation file shared previously require Premium DevZone access that you require to register for the access. May I know if you have register it and able to access to the link?
Sazzy_Intel
bsp_user
Yes, I retrieved the doc. Thank you
Meghak
Hi bsp_user,
Greetings for the day!
Thank you for confirming the details.
Please be informed we will now close this request.
Please feel free to post a new question if you may have any inquiry in the future.
Thank you for using Intel products and services.
Megha K
