Ethernet Products
5739 Discussions
I226-V 1.1.4.42 driver error with Windows 10 Pro
Byteus
Downloaded the 28.3 Ethernet driver package with version 1.1.4.42 drivers from Intel to setup a I226-V NiC on an up to date Windows 10 Pro install and it complained about the driver and failed to start showing an error.   Downloaded 1.1.4.42 drivers from station-driver and they properly installed and the card works.  While having the same version the driver dates are a month earlier on the station-drivers files.  There appears to be an issue with the NDIS68 drivers in the 28.3 x64 package.  Neither running the exe or manual install works.
Srri
Hello Michael,
Can we know what is the error and can you provide the screenshot of the error message.
Thanks and regards,
Srri
Intel Customer Support
Byteus
Sure, it's Error code 39.  Running the package exe installs successfully with no errors but the device shows this error.  I tried a manual install of the NDIS68 folder for Pro2500 to get the screen shots.  Intel1-3 cover the errored Driver,  Intel 4 is the working station-driver driver with the same version.  I'm running this on an old Gigabyte P55 with Windows 10 Pro fully updated.
I tried downloading the package again, it's not a corrupt download or files, there's just something amiss here.  The card I'm using is this Chinese IV226-V adapter purchased from Amazon.
Byteus
Here's the Station-driver zip and Intel's wired driver package 28.3, you can compare the files to see what was changed from this earlier release.
Hayat
Hi Byteus,
Thank you for the information provided. We are currently reviewing the information and will get back soon with more updates.
In order for us to investigate further, please provide the information below:
- Is it a prebuilt or the card purchased separately?
- Any software or hardware changes to your system and software/network router/switch recently?
- SSU Logs: https://www.intel.com/content/www/us/en/support/articles/000057926/memory-and-storage.html
Hayat
Hayat
Hello Byteus,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply here to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank You.
Hayat
Intel® Customer Support
Hayat
Hello Byteus,
Since there are no replies, we will proceed to close the thread.
Please be informed, once the thread is closed it will no longer be monitored by Intel.
Kindly open a new thread if you have further questions.
Hayat
