Ethernet Products
5601 Discussions
I226 programming on ARM platform
ucantieni
Hi!
We're working on a custom implementation of then I226 to be used with an ARM base system. For programming the NVM I've looked into the LANCONF tool. Unfortunately, there seems no version available that is compatible to run on ARM.
Is there such a tool you can provide / any other way you can suggest?
Kind regards,
UC
Ragulan_Intel
Hi Ucantieni,
Warm greetings and good day to you.
Thanks for reaching out to Intel Community.
Please be informed that as per your query, we will be moving this thread to embedded connectivity for further advise.
Regrads,
Ragulan_Intel
CarlosAM_INTEL
Hello,  @Ragulan_Intel:
We need to clarify that this forum is not related to an Intel Embedded Platform (it is related to an ARM platform).
Due to this, the customer request is out of our scope of support.
Please consider this information when you provide the previous suggestion, or transfer any forums to the channel that you mentioned in your previous communication.
@CarlosAM_INTEL.
