Ethernet Products
5720 Discussions
I350-T2 + I219V teaming in Win 10 build 14393.2214
邱仕翔
I also have teaming problem with I350-T2 + I219V
I use win10 64-bit with build 14393.2214 (released at 17th, April) and the latest driver (https://downloadcenter.intel.com/download/25016/Intel-Network-Adapter-Driver-for-Windows-10?product=36773 Download Intel® Network Adapter Driver for Windows® 10 )
I can successfully teaming these two adapters(using intel ANS adaptive load balancing), and it works fine in normal situation.
BUT, its fail-over function doesn't work at all.
Here is how I test fail-over function:
I connect with 3 client pc and use Iperf2.0.10 to test the connection speed.
Then, I intentionally disable one adapter, theoretically, it will continue connecting with all 3 pc with a lower speed(which I saw under win8), but the result I see is connection abort (sometimes one or two of them, sometimes all) with two kinds of error message : "write failed, connection reset by peer" or "software cause connection abort".
This problem didn't happen under win8 I test couple weeks ago.
Does anyone have any idea?
Hi Lala_lancelot,
Thank you for posting in Wired Communities. I branch out your post here as you have a different issue. Can you share more information for us to better check:
1) What is the brand and model of the system where is the I219-V is installed?
2) Is the I350-T2 an external network adapter or an onboard NIC as well?
3) Can you clarify about the 3 client PC? Are you connecting these 3 client PCs on the same switch in order to access the Windows 10 PC (with teaming configured) on the same switch?
4) Are both Windows 8 and Windows 10 you tested have the same setup?
5) Please refer to the failover information at https://www.intel.com/content/www/us/en/support/articles/000007536/network-and-i-o/ethernet-products.html Intel® Advanced Network Services (Intel® ANS) Advanced Settings for... , can you check if probe is enabled?
Please feel free to update me.
Sharon T
邱仕翔
Hi Sharon,
Thanks for your support and kindly find my answer below:
=> I'm not so sure if this is the information you want: I'm using GIGABYTE GA-B150M-D3H which has an onboard NIC I219-V.
=> I350-T2 is an external dual port network adapter.
=> All of them are H81m-itx (https://www.asrock.com/MB/Intel/H81M-ITX/index.us.asp ASRock > H81M-ITX )
=> Yes
=> When I tested on Windows 8, i used the latest driver for Windows 8 (https://downloadcenter.intel.com/download/21642/Intel-Network-Adapter-Driver-for-Windows-8-?product=36773 https://downloadcenter.intel.com/download/21642/Intel-Network-Adapter-Driver-for-Windows-8-?product=36773 )
As for Windows 10, I also use the latest version(23.1) for Windows 10, both of the drivers are valid for I219-V and I350-T2.
Beside OS system and driver, I think other setup (including client PC) are identical.
=> Yes, probe function is enabled. The packet type is broadcast and the max number of probe retries is 10.
Thanks for your support again!
Hi Lala_lancelot,
Thank you for the information provided. Can you disable the STP (Spanning Tree protocol) on the switch, please refer to the teaming implementation consideration information at https://www.intel.com/content/www/us/en/support/articles/000005667/network-and-i-o/ethernet-products.html?_ga=2.32225853.2037610676.1526628600-1240918846.1523867390&erpm_id=1500765
Please feel free to update me. Thank you.
Sharon T
Hi Lala_lancelot,
Please feel free to provide the update.
Sharon T
Hi Lala_lancelot,
Recently we have a new driver version 23.2, you may try install the driver to see this will make any difference:
https://downloadcenter.intel.com/download/22283/Ethernet-Intel-Ethernet-Adapter-Complete-Driver-Pack?product=36773
Please let me know also if your switch has the STP disabled. Looking forward to your reply, Thank you.
Sharon T
Hi Lala_lancelot,
Please feel free to update me if you have tried the driver and disable the STP. Looking forward to your reply.
Sharon T
Intel Customer Support
Agent under contract to Intel
