I am designing a system that will use the x550. I want to have the future possibility of IEEE 1588 precision time protocol. The SDP (software defined pins) of the x550 will be connected to an FPGA for this purpose. Is it important to have an ultra accurate clock source on the x550 for 1588? Or does the FPGA require this clock source?
Hi pfrechette,
Have you tried check on the data sheet below if this could be of any help?
http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/ethernet-x550-datasheet.pdf
wb
I have the latest datasheet. From it, I cannot determine where the best place in the design is to put an ultra accurate clock source.
Hi Pfrechette,
Thank you for the reply. I will further check on this.
rgds,
wb
Hi Pfrechette,
Given your query involves design, we'd suggest posting it in our embedded community for assistance.
https://embedded.communities.intel.com/community/en/content https://embedded.communities.intel.com/community/en/content
Vince
Hi Pfrechette,
Please register at embedded design center to access the information.
http://www.intel.com/content/www/us/en/design/support/account-support.html
Rgds,
wb
