Hi all,
I am setting up the test environment for FM10000. I downloaded IES( Intel Ethernet Switch Software ) api and tried to install it in Unbuntu 16.04 LTS. I followed the guideline in some Documents .Generally, what I do is cd to ies/src and type command
" sudo make install PLATFORM=rubyRapids REF_PLATFORM=libertyTraili INSTALL_DIRECTORY=/home/brayn/Documents".
I go back and check my folder( /home/brayn/Documents ) , there is nothing installed in it so I assume I failed ? Below is the message shows on terminal.
brayn@brayn-Ultra-27:~/Documents/ies/src$ sudo make install PLATFORM=rubyRapids REF_PLATFORM=libertyTraili INSTALL_DIRECTORY=/home/brayn/Documents
make[1]: Entering directory '/home/brayn/Documents/ies/src'
/bin/mkdir -p '/usr/local/lib'
/bin/bash ../libtool --mode=install /usr/bin/install -c libFocalpointSDK.la libLTStdPlatform.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libFocalpointSDK-4.1.3_0378_00314560.so /usr/local/lib/libFocalpointSDK-4.1.3_0378_00314560.so
libtool: install: (cd /usr/local/lib && { ln -s -f libFocalpointSDK-4.1.3_0378_00314560.so libFocalpointSDK.so || { rm -f libFocalpointSDK.so && ln -s libFocalpointSDK-4.1.3_0378_00314560.so libFocalpointSDK.so; }; })
libtool: install: /usr/bin/install -c .libs/libFocalpointSDK.lai /usr/local/lib/libFocalpointSDK.la
libtool: install: /usr/bin/install -c .libs/libLTStdPlatform-4.1.3_0378_00314560.so /usr/local/lib/libLTStdPlatform-4.1.3_0378_00314560.so
libtool: install: (cd /usr/local/lib && { ln -s -f libLTStdPlatform-4.1.3_0378_00314560.so libLTStdPlatform.so || { rm -f libLTStdPlatform.so && ln -s libLTStdPlatform-4.1.3_0378_00314560.so libLTStdPlatform.so; }; })
libtool: install: /usr/bin/install -c .libs/libLTStdPlatform.lai /usr/local/lib/libLTStdPlatform.la
libtool: install: /usr/bin/install -c .libs/libFocalpointSDK.a /usr/local/lib/libFocalpointSDK.a
libtool: install: chmod 644 /usr/local/lib/libFocalpointSDK.a
libtool: install: ranlib /usr/local/lib/libFocalpointSDK.a
libtool: install: /usr/bin/install -c .libs/libLTStdPlatform.a /usr/local/lib/libLTStdPlatform.a
libtool: install: chmod 644 /usr/local/lib/libLTStdPlatform.a
libtool: install: ranlib /usr/local/lib/libLTStdPlatform.a
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin:/sbin" ldconfig -n /usr/local/lib
Libraries have been installed in:
/usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
make[1]: Nothing to be done for 'install-data-am'.
make[1]: Leaving directory '/home/brayn/Documents/ies/src'
Can anyone have experience help solve this problem?
Also I can't find HNI ( Host Network Interface) driver mentioned in the guideline, Where should I download it ? Thanks!
Hi Kimi_chen,
Thank you for posting at Wired Communities. I sent you private message, please reply from there.
thanks,
sharon
Hi Kimi_Chen,
Further checking, please visit the Intel premier support site to submit your inquiry to get further support.
Here is the reference site on how to login and access.
https://www.intel.com/content/www/us/en/design/support/ips/training/access-and-login.html https://www.intel.com/content/www/us/en/design/support/ips/training/access-and-login.html
Hope the above information help.
regards,
sharon
