Hi to all
I recently updated my system with an SSD.
After the update, the driver for intel network adapter 82579V started having some problems. Under device manager, it is identified intermittently with 82579V or LM. When identified as V works correctly, otherwise I get no internet connection.
I have seen this is a known problem, although i did not find a common solution. I obviously tried reinsalling the drivers with no success.
I get no internet on cold boot, but if i run the installer driver PROWin64.exe sometimes it identifies it with V and i get back internet.
It is strange that this problem came up after updating the system... Any suggestions?
Hello TDePo,
Are you using Windows 10? If yes, please try to install the NVM Update Utility. Kindly open the link below to download the update.
https://downloadcenter.intel.com/download/22026/NVM-Update-Utility-for-Intel-82579V-Gigabit-Ethernet-PHY-Network-Connection
If you have questions, please let us know.
Michael L.
Intel Customer Support
Under Contract to Intel Corporation
Hello TDePo,
Just want to check if you tried our last recommendation and what is the update?
Michael L.
Hello TDePo,
Just checking if you tried our last recommendations
Michael L.
Hello TDePo,
Just making another follow up if you are done with our last recommendation.
Michael L.
