Good day,
Can you please confirm if INTEL part number is valid and orderable.
Does this part number match against the description?
If we need to order this item in T&R, what is the correct and orderable part number?
Is this item RoHS 3 compliant?
What is the MSL for this item?
MPN: 99AFMW
Description: IC,I226-LM,C,SRKTS,2.5G ENET,QFN56
Carlos Burciaga
Components Engineer
Hello Carlos,
Regarding your questions:
Kindly check this Intel® Ethernet Controller I226-LM.
You might need to have a CNDA account access to be able to check the site.
Please follow this How to Apply for an Intel® Resource and Documentation Center (RDC) and/or Intel® Developer Zone (Intel® DevZone) Account to get your account created.
Please let us know the outcome after you have checked it and will be happy to assist if any other troubleshooting required for this issue.
Hayat
Hello Carlos6,
Regarding your thread, we are following up to enquire if you have further questions or clarifications regarding this case.
Else if none, we will proceed to close the thread.
Once the thread is closed, it will no longer be monitored by Intel. Kindly submit a new thread should you need further assistance. We will be more than glad to continue assisting you.
Looking forward on receiving your reply!
Hayat
Intel® Customer Support
Hello Carlos6,
This message is to inform you about the thread closure.
Hayat
