Ethernet Products
5601 Discussions
Iavf driver version upgraded to 4.11.3 on ubuntu 2204, Issues in bringing up and down iavf devices
srikanthn81n
Iavf driver version upgraded to 4.11.3 on ubuntu 2204, Issues in bringing up and down the devices managed by iavf driver.
Please see following errors in kernel logs. Can you advise what could be the cause of the issue?
May 27 21:15:12 kernel: [ 753.506096] ------------[ cut here ]------------
May 27 21:15:12 kernel: [ 753.506101] NETDEV WATCHDOG: ens8 (iavf): transmit queue 4 timed out
May 27 21:15:12 kernel: [ 753.506197] WARNING: CPU: 7 PID: 0 at net/sched/sch_generic.c:529 dev_watchdog+0x21f/0x230
May 27 21:15:12 kernel: [ 753.506207] Modules linked in: iptable_raw xt_CT xt_tcpudp bpfilter udp_diag raw_diag unix_diag af_packet_diag netlink_diag tcp_diag inet_diag isofs xt_multiport ipt_rpfilter ip_set_hash_net veth wireguard curve25519_x86_64 libchacha20poly1305 chacha_x86_64 poly1305_x86_64 ip6_udp_tunnel udp_tunnel libcurve25519_generic libchacha ip6t_REJECT nf_reject_ipv6 ipt_REJECT nf_reject_ipv4 xt_mark xt_set ip_set_hash_ip ip_set_bitmap_port ip_set_hash_ipport ip_set_hash_ipportnet ip_set_hash_ipportip ip_vs_rr ip_set ip_vs nfnetlink_acct dummy xt_comment xt_conntrack nft_chain_nat xt_MASQUERADE nf_conntrack_netlink xfrm_user xfrm_algo xt_addrtype nft_compat nf_tables nfnetlink sunrpc binfmt_misc nls_iso8859_1 kvm_intel kvm input_leds serio_raw joydev floppy sch_fq_codel ip6table_raw xt_bpf ip6table_mangle ip6_tables ip_gre ip_tunnel gre iptable_filter iptable_mangle iptable_nat xt_nat xt_statistic xt_REDIRECT nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 dm_multipath xt_owner scsi_dh_rdac
May 27 21:15:12 kernel: [ 753.506319] scsi_dh_emc overlay scsi_dh_alua br_netfilter bridge stp llc drm efi_pstore ip_tables x_tables autofs4 btrfs blake2b_generic raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c raid1 raid0 multipath linear hid_generic crct10dif_pclmul crc32_pclmul usbhid ghash_clmulni_intel hid aesni_intel crypto_simd virtio_net iavf(OE) cryptd net_failover psmouse virtio_rng failover virtio_blk
May 27 21:15:12 kernel: [ 753.506433] CPU: 7 PID: 0 Comm: swapper/7 Tainted: G OE 5.19.0-50-generic #50-Ubuntu
May 27 21:15:12 kernel: [ 753.506440] Hardware name: OpenStack Foundation OpenStack Nova, BIOS 1.10.2-1ubuntu1 04/01/2014
May 27 21:15:12 kernel: [ 753.506447] RIP: 0010:dev_watchdog+0x21f/0x230
Subhashish
Hello srikanthn81n,
Greetings from Intel !!
Thank you for your post. We are reviewing your request and the errors from Kernel logs. Aside this we request your help with below:
  1. Please confirm the exact Ethernet controller/Adapter model that you are using (Iavf usually is with 500/700/800 series of Adapters/Controllers). Please help with exact model for your controller/adapter.
  2. As you mentioned the virtual function driver was updated to 4.11.3 and you faced the issue, please confirm when it was working properly and with which exact VF driver version?
  3. What is the corresponding PF driver installed in your case?
  4. Also what is the firmware version of the ethernet adapter/controller that is installed?
Subhashish_Intel.
srikanthn81n
Hi Subhashish,
    Please find reply inline.
  • Please confirm the exact Ethernet controller/Adapter model that you are using (Iavf usually is with 500/700/800 series of Adapters/Controllers). Please help with exact model for your controller/adapter
  • [Reply] -  Intel Fortville XXV 710
  • As you mentioned the virtual function driver was updated to 4.11.3 and you faced the issue, please confirm when it was working properly and with which exact VF driver version?
  • [Reply] - From last 1 year we are using iAVF driver built into linux kernel version 5.19.0-50-generic. (Linux stopped displaying iAVF version from linux kernel version 5.9, https://github.com/torvalds/linux/commit/34a2a3b83e2caf18ab85627f9c6a78bc0a1d1520)
  • What is the corresponding PF driver installed in your case?
  • [Reply] - i40e (2.12.6.8)
  • Also what is the firmware version of the ethernet adapter/controller that is installed?
  • [Reply] - 9.20 0x8000d960 22.0.9
Srikanth
Poojitha
Hi srikanthn81n,
Greetings for the day!
Thank you for sharing the details. Could you please confirm the system model you are using the adapter with, and kindly share clear front and back pictures of the adapter, including the label details?
This information will help us review everything thoroughly and assist you further.
We appreciate your understanding!
Poojitha N
Subhashish
Hello srikanthn81n,
Thank you for your response. We are working on this issue internally and reviewing the Kernel logs errors as well. We will update you again with our findings.
Kindly await our next update.
Subhashish_Intel.
Sachinks
Hello srikanthn81n,
Greetings!
We have checked this with our team and we request you to update the driver and NVM firmware to the latest version.
Note: Kindly update to the most current ice and i40e driver prior to running the NVM Update Tool to ensure the newest features of the NVM image can be installed.
Current driver version: i40e (2.12.6.8)
Current NVM version: 9.20
Please refer Table 10 of feature support Matrix for NVM and Software Compatibility - XXV710. Kindly find the feature support Matrix document in the below link :
https://www.intel.com/content/www/us/en/content-details/332191/intel-ethernet-controller-x710-xxv710-xl710-feature-support-matrix.html
Please don’t hesitate to contact us for any further assistance.
Thank you for using Intel products and services.
Sachin KS
Subhashish
Hello srikanthn81n,
Greetings !!
This is just to follow up whether you had the opportunity to review our last post or if you have tried the suggestions from our end. Please do write back to us in case you have any further concerns.
We remain attentive to your next response.
Subhashish_Intel.
Subhashish
Hello srikanthn81n,
Greetings for the Day !!
This is second follow up regarding the ongoing issue reported to us. We are eager to ensure a smooth resolution and would appreciate if you can confirm if you have reviewed and tried our suggestions and what is current status whether the issue is resolved or if any other assistance is required from our end.
Looking forward to hear from you.
Subhashish_Intel.
Subhashish
Hello srikanthn81n,
This is third follow up regarding the ongoing issue. We had suggested previously for updating the drive and nvm. We would like to know if you got the opportunity to implement the same and if yes, what were your findings. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Please feel free to respond to this email at your earliest convenience.
Subhashish_Intel.
srikanthn81n
Hi Subhash,
    Have forwarded recommendations to our Managment after reviewing feasibility of upgrade. We are not very keen to upgrade both Firmware and driver version at this point as this is causing lot of disruption to Production.  We are working on updating just iAVF driver version to see if that helps. Thank you for gathering initial analysis report and sharing with us. You may close the ticket.
Srikanth
