Ethernet Products
5614 Discussions
Imaging Computers WDS
WWrig2
Hello.
Hopefully someone can help me here.
I am trying to image computers via WDS and I have Dell OptiPlex 9020's. The only way I can get the computers to connect to the server is if I downgrade the BIOS to A01. Then I am able to deploy the image to the pc.
Can someone tell me if this is something that needs to be updated on the server and if so, can you tell me how?
I can't see it being the pc as an issue.
Any help would be appreciated.
st4
New Contributor III
Hi Billw001,
Thank you for the post, Just to double check if you are referring to using Windows Deployment service?
What is the server you used? Thanks.
rgds,
wb
