Ethernet Products
5536 Discussions
Installing network drivers without internet
pbubs
My HP Pavillion laptop can't connect to the internet because it doesn't have the correct drivers. It's supposed to have the network adapter called "Intel(R) Wi-Fi 6 AX200 160 MHz" but that isn't showing in the Device Manager. So I went on separate laptop to download this adapter from the Intel website on a flashdrive to transfer it, however the network adapter won't install because "this installation requires Windows 10.017763 or newer," which I think is the equivalent of version 1809. My laptop is Windows 10 version 1803. I also tried to download the Windows 10 version 1809 update to my flashdrive, but it requires a network connection to do so. Basically I'm stuck in a loophole of not having a connection. I also tried getting an ethernet cable but my laptop doesn't have the correct port to be connected. Is there anything I can do to get an internet connection?
AlHill
Get yourself something like this:
https://www.newegg.com/p/17Z-00EK-00BA6?Description=realtek%20usb%20ethernet%20adapter&cm_re=realtek_usb%20ethernet%20adapter-_-9SIAFJVAP37969-_-Product&quicklink=true
Then, connect to the net using your ethernet lan cable.
Next time, do not let youself get so out-of-date.  1809 was FOUR years ago.
AlHill
pbubs
Thanks, I'll try that.
