Ethernet Products
5821 Discussions
Int E810 10/25GbE SFP28 Adptr - Windows2019 - 25GbE not working
Zokhidjon
Hi, all!
The configuration is: Switch - Mikrotik CRS504-4XQ - DAC: Mikrotik XQ+BC0003-XS+ and Ethernet Card on Windows 2019 Driver Version: 1.12.148.0 INT E810 10/25GbE SFP28 Adptr Part Number: P08443-B21
Problem is, cannot get connected 25G, no link,
But 10G work well,
Can u pls help ?
Zokhidjon
Hi, all,
I think, problem is solved.
Needed select fec91 on port, and 25 Gb/s linked well ...
Irwan_Intel
Thank you for contacting Intel Customer Support.
In order to assist you with troubleshooting, please follow the steps provided below and kindly inform us of the results.
1. Please provide the System Support Utility (SSU) log of your system. This will allow us to check your Adapter details and configuration. Kindly refer to the steps below.
https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
2. Update the firmware to the latest version. Download the latest version
https://www.intel.com/content/www/us/en/download/19625/non-volatile-memory-nvm-update-utility-for-intel-ethernet-network-adapters-e810-series-windows.html
3. Update the drivers to the latest version. Download the latest version
https://www.intel.com/content/www/us/en/products/sku/189760/intel-ethernet-network-adapter-e810xxvda2/downloads.html
3. Follow the "Optimizing Performance" guide on page 55 in Adapter User Guide for Intel® Ethernet Adapters
https://www.intel.com/content/www/us/en/download/19373/adapter-user-guide-for-intel-ethernet-adapters.html?wapkw=adapter%20user%20guide
Please let us know if you have further questions or concerns.
Irwan_Intel
Irwan_Intel
Hi Zokhidjon,
I'm following up to check if you've had a chance to try the steps mentioned in my previous post
Please let me know if you have implemented the changes and if they have resolved the issue for you?
Looking forward to hearing from you and ensuring everything is working smoothly.
Irwan_Intel
