Ethernet Products
5388 Discussions
Intel 1219-V bootutility
Jubbarelly
Hi
Is there a boot utility available for the 1219-V NIC?
The above isnt listed as being compatible in the Intel® Ethernet Connections Boot Utility, Preboot Images, and EFI Drivers page:
https://www.intel.com/content/www/us/en/download/15755/intel-ethernet-connections-boot-utility-preboot-images-and-efi-drivers.html
When I do use the utility I get the below error which I presume is because its not a supported NIC:
Microsoft Windows [Version 10.0.22631.3296]
(c) Microsoft Corporation. All rights reserved.
C:\Windows\System32>cd C:\Intel29.0\APPS\BootUtil\Winx64\
C:\Intel29.0\APPS\BootUtil\Winx64>BOOTUTILW64E.exe -NIC=1 -up=pxe -file=BootIMG.FLB
Intel(R) Ethernet Flash Firmware Utility
BootUtil version 1.40.05.0
Copyright (C) 2003-2023 Intel Corporation
Option ROM area in the flash is not supported for this device on port 1
Port Network Address Location Series WOL Flash Firmware Version
1 A8B13B7B9DF8 0:31.6 Gigabit N/A FLASH Not Present
If someone could point me in the right direction so that the NIC can be flashed that would be great.
Jub
Dineshbabu
Hi Jubbarelly,
Greetings!
Thank you for posting in the Intel Community. Upon investigation, we have found that the boot utility is not compatible with the Ethernet connection I219-V.
Please confirm whether the Ethernet connection is embedded in the system.
Could you kindly provide us with the system information to assist you further?"
Dinesh
Jubbarelly
Hi Dinesh
It's a daughter board that connects via a ribbon cable to the main board and is in a HP ProBook 440 G8 laptop.
Thank you
IntelSupport
Community Manager
Hello Jubbarelly,
Greetings for the day!
As per this case, please confirm whether the Ethernet connection is embedded in the system.
Manoranjan.
Jubbarelly
Hi
It is embedded.
What system information do you need?
Thank you
IntelSupport
Community Manager
Hello Julian,
Greetings for the day !
Intel ethernet connection i219 V NIC is not comaptible with ethernet connection boot utility since it is embedded on HP ProBook 440 G8 laptop.Kindly get in touch with HP boot utility. They will be best equipped to provide support and address any concerns related to the product's warranty coverage.
Unfortunately we are unable to extend support for this product, as it falls outside of our support boundaries.
Feel free to reply to this email if you have any further questions or need assistance. We're here to help.
Varsha
