Ethernet Products
5821 Discussions
Intel 1219 ethernet did not work woke up from sleep
文何
I am using Gigabyte H170-H3DP motherboard with i5-6500 cpu, when the computer woke up from sleep, the intel 1219-V(2) ethernet card did't work, and changed to 10Mbps, could not receive any packet,until the next restart of the OS.
Using Win10 (Version1511) X64 with the latest update and Intel Network Adapter Driver V21.0 installed.
I tried to disable the power saving of the ethernet card, however it didn't work.
Hi marco_hwt,
Thank you for the post. Have you tried using the customized driver from Gigabyte board as this is an onboard NIC.
wb
文何
Already changed to the driver from Gigabyte (seem to be using Intel version 20.7), it was also the same.
Hi Marco_hwt,
Have you tried upgrading the board BIOS?
rgds,
wb
文何
Already using the latest version of BIOS (Ver.F4)
Hi Marco_hwt,
Please check in the BIOS for any related power management setting.
rgds,
wb
文何
This is the power management screenshot of my BIOS setting. Please review.
Hi Marco_hwt,
Thank you for the information. I can see the Platform power management is disabled, please enable this option and run a test to see if this make any difference. I would suggest you to contact Gigabyte* support as this is onboard NIC which integrated on the system, the board vendor knows the overall BIOS and platform setting better. Here is the website concerning support for OEM onboard NIC:
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006628.html?wapkw=oem+network
rgds,
wb
Hi Marco_htw,
Have you tried the suggestion and please update if the issue is fix?
thanks,
wb
Hi Marco_hwt,
Good day. Please feel free to contact Gigabyte support regarding WOL documentation for their system.
rgds,
wb
