Ethernet Products
5719 Discussions
Intel 82567V-2 Windows 10 WOL
JGigo
Hi all,
I wanted to get some info regarding an Intel 82567V-2 onboard NIC and WOL in Win 10. Currently the NIC is using the MS driver in Win 10 as there is no official Intel driver available. I want to enable WOL which I have enabled in the mobo BIOS, and also have the Allow Magic Packet option turned on in the NIC's power management settings. However, there is no WOL option in the advanced tab for the NIC. I cant get WOL to work at all, Im using the Aquila WOL app. Has anyone setup WOL on this adapter using the MS driver in Win 10 and got it working? Thanks!
st4
New Contributor III
Hi JGIG73,
YOu may check with Microsoft since this is Windows 10 driver and also check w/ the board vendor where this chipset was embedded for the customized driver.
wb
