Ethernet Products
4536 Discussions
Intel 82579 for Windows CE 6.0 - Loss of connectivity
I have some problems running Intel 82579 driver (E1C51CE6) in Windows CE 6.0. Communication with the ethernet interface is aparently OK but after some time connectivity is lost.
In addition I can see the following traces to be printed:
WINCE 6.0 E1Q::PhyUpdateAdaptiveIFS: Adaptive IFS exiting--adapter is stopped or resetting
ndisMResetCompleteStage2: Internal reset
I have some concerns I want to share with you:
1- I got this driver dll from "Intel® Ethernet Drivers for Microsoft* Embedded Operating Systems v12" https://downloadcenter.intel.com/download/24555/Intel-Ethernet-Drivers-for-Microsoft-Embedded-Operating-Systems https://downloadcenter.intel.com/download/24555/Intel-Ethernet-Drivers-for-Microsoft-Embedded-Operating-Systems. Is there any newer release of this driver?
2- I guess this controller is no more supported by Intel for Windows CE 6.0. Howerver, is it possible to get the source code of this driver?
3- Any idea related to the traces that are printed?
Any hint is appreciated!
Hi Ivess,
Thank you for the post. I need to further check on this, will update you once there is any finding.
rgds,
wb
Thanks for you answer. I'll appreciate any help.
Hi Ivess,
Just to double check are you referring to Intel 82579LM or 82579V ethernet controller?
wb
Hi wb,
It's 82579LM controller.
Hi Ivess,
Thank you for the confirmation.
rgds,
wb
Hi Ivess,
Good day. Further checking you need to login to embedded communities for support.
https://embedded.communities.intel.com
thanks,
wb
Hi wb,
I don't fully understand you. Should I write in https://embedded.communities.intel.com https://embedded.communities.intel.com asking for support? Or should I expect more support from you side?
Thanks again,
Hi Ivess,
Thank you for the reply You need to login to embedded support communities to post your inquiry to get further support. Hope this clarified :)
rgds,
wb
Ok, Thank you for help.
Hi Ivess,
You are welcome :)
rgds,
wb
Hi Ivess,
Please feel free to update me if you were able to log in embedded communities.
wb
Hi wb,
I did log in embedded communities. I posted the same enquiry there.
Thank you,
Hi Ivess,
Thank you for the update.
rgds,
wb
